Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirpool washer LSN8244AQ0 motor spins but agitator does not move.
Clean touch, 8 cycle, 2 speed
You can hear the motor whining, but nothing else happens
    Novelist:
    Champion:
  • 261 Answers
Ok this is a old school machine. Have a look at the drawing below. So no agitation or spin? How about the pump, does it drain? Now if it drains and thatis it then item 13 below is a coupler that is probably out. You can pull the machine out and tilt it back and using a flashlight examine for black dust and touch to see if it is soft in spots and the two white flanges are intact. You may have to remove the pump and motor to inspect.Use part 285753A .
Posted on Oct 15, 2008
    Problem Solver:
My washwe machine not spins but agitator does not move and don;t wash very good the all some vary now about this problems tk
Posted on Feb 27, 2009
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
I have a maytag over capacity plus heavy duty 2 speed 10 cycle washer it fills with water fine you hear the motor kick in to girate but doesent spin or you put it on spin cycle it sounds like it is...
The motor is working, but the mechanism not engaged by the helix so the shaft can not move therefore no agitation or spinning. Motor is designed to turn 2 directions: clockwise and counterclockwise for agitation and spinning. Therefore there are 2 mechanisms to assist these tasks. The drain is control by a separate pump and it is still good also.
The tube has to be out to replace the helix for agitation and a part to engage with the spinning rotation to release the brake so the spinning function can work. These parts are cheap, but the the labor is not. Hope this can help
Jan 09, 2010 | Washing Machines
Whirpool model GSQ9669LW1 basket does not spin after replacing the broken coupler between motor and transmission. Motor showed good continuity using volt-owm meter on ohms setting on low, medium, and high...
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 06, 2017 | Whirlpool Washing Machines
Wont drain or spin
Hi, Most possible causes are:-
1.Make sure the lid is closed. There is a switch inside that completes the connection. Your washer may not spin or agitate if this connection is not completed. Make sure that the speed selector switch is not between speeds. Verify that the washer is not in a soak cycle. You can also reset the water level up or down to make sure that the water level control switch isn't stuck. If you hear a humming sound when the washer is full of water, you may have something stuck in the drain pump.
2.If one of these is not the problem, check the belt. The main drive motor has two distinct functions. The first function is to spin the basket; the second function is to reciprocate your agitator. Inside your washer's transmission is a crank type gear and connecting rods that are used to agitate the washer, with the spinning coming from the washer motor itself. This usually entails some sort of clutch mechanism. Some things to check if your washer is not agitating and/or spinning are:
3.If you notice weak or no agitation, the splines connecting the agitator to the drive shaft may be stripped and need to be replaced.
4.After a lot of use, belts can become worn or damaged. Replace any worn or damaged belts immediately. If you have a broken belt, replace it and check the pulley to make sure it's not seized.
5.Sometimes the drive pulley can wear out and it won't turn the drive belt. Look for wear marks, pits, or uneven spots. It's best to just replace it with a new pulley.
6.Many washers use a reversing motor. Sometimes it will continue to work in one direction even if it won't spin in the other direction. If your washer has a drive motor issue, you probably need to replace the motor with a new one.
7.The lid switch is a safety device that's there to protect you from sticking your hands into a spinning washer. If this switch goes bad, the washer will not work. You will have to replace it. It is inside the main housing for the washer, and located near the door frame.
8.The coupler connects the motor to the transmission. After lengthy use, this plastic and rubber coupler can wear out. If this happens, you need to replace it.
9.Transmission and clutch assemblies can cause agitator and spinning problems They are fairly complex.
Regards, mannu_rakesh
Sep 11, 2009 | LG WFT1071TP Top Load Washer
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Washer/pump
It could mean that or it could also mean you have a foreign object trapped in the pump casing .. You can get replacement parts at this website.. http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope this helps.
Sep 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
Apr 16, 2008 | Maytag PAV2300 Top Load Washer
Motor whine w/ agitation & no high speed spin
try undoing the pump assy (just unclipp and move it aside) no need to disconect hoses yet. tyspinning now, if quiet then theres csomethin in the pump, you may get lucky and be able to pull whatever it is out!
Mar 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Calypso GVW9959K Top Load Washer Logo
503 people viewed this question
Dan Webster
Dan Webster
Sal De
