Question about HP Office Equipment & Supplies
I re ink my printer black ink hp56 and its not printing clear
Re ink hp cartage
Posted on Mar 18, 2009
Can a hp 56 ink cartridge be substutited for a 60 hp black ink cartridge
No, it cannot. I tested it on an HP DeskJet F2430. The HP56
will not fit in the HP60 carrier.
Dec 04, 2012 | HP DeskJet F4280 All In One Printer InkJet
I have a HP officejet J4550 All in one and recently purchased an ink cartridge with the same number but is the xl and it prints for a while and then I get an error about being Incompatible
You must be using HP56.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP5510 is not a new model however has not cause major problem.
Good practical and durability is good.
It seems like you are out of ink....especially black.
Pls refill or get brand new one.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 13, 2011 | HP Officejet 5510 All-In-One Thermal...
What is problem when a ink jet printer (hp psc 2410xi photosmart) has a red stripe in the black print?
Using HP56, 56 cartridge for your printer?
Well, when you are out of black ink, that's what it happens.
Pls refill your cartridge or replace with new one.
How you refill? very easy.
May 12, 2011 | HP Office Equipment & Supplies
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Print cartridges, are both black and color required to operate?
You need both a black and a tri color. Costco and Sam's club sell pkgs with both for a good price!
Sep 24, 2008 | HP PSC 2210xi All-In-One InkJet Printer
Continue to receive "Remove and check black cartridge" message
I would call hp again. The cartridge you purchased is covered for a one year warranty and they should be able to replace to make sure issue is not with the cartridge itself. Since this is not a computer issue tell them you have a mac and you will get to Canada support instead of India.
Jul 31, 2008 | HP Officejet 5510 All-In-One Thermal...
I have a HP 6656A Printer Cartridge that sometimes works good and other times will fail the power on check. Error message varies between Ink Cartridge not compatabile, Check Color Cartridge (even though...
I got hold of another set of 56 and 57 Ink cartridges. By swapping the four of them in and out of two printers, I determined that one of the Black 57 cartridges was bad and caused a missleading error message to pop up saying to check the Color 57 cartridge. I don't know why I was getting different messages at first, but after several swaps in and out of two printers, the error message finally became consistant and I learned that the one Black 56 cartridge was the faulty guy. One Color 57 cartridge printed good but the other (newer one) left streaks on the Cyan and Magenta colors even after soaking the head surface for a few minutes and cleaning it with inkjet cleaner fluid.
The end result is that I have one good Color 57 cartridge and one good Black 56 cartridge which work good in two different printers.
By the way, can you email a labled pinout reference drawing of the hp56, 57 & 58 Ink Cartridges???
Reggie Bostwick
Jul 07, 2008 | HP Office Equipment & Supplies
Epson c60 problem
methinks you'll need to do a clean and calibrate on those new ink stations.
May 11, 2008 | HP PhotoSmart 7260 InkJet Printer
Cradle jam after inserting ink cartridge, wont align
May-15-2008
in a HP-PSC-1210, replaced empty HP56 black-inkjet cartridge.
Afterward, printer gave error message AND unable to "dismount" the cartridge.
Finally discovered that an HP57 color-inkjet cartridge had accidentally been mounted/installed. A handyman relative was able to dismount the (wrong) cartridge.
Cradle did not actually jam, though printer would not print.
Apr 21, 2008 | HP Office Equipment & Supplies
48 people viewed this question
Seeker5211
Seeker5211
