Question about Canon Digital Rebel XSi Digital Camera
Canon Rebel Xsi shuts off and blue light flashes (WB button)
Hi, my camera is just 3 days old. Seemed to work fine, but now suddenly after taking a picture, the camera shuts off (battery indicator shows full), and the blue light (on the WB/picture transfer button) starts flashing. Sometimes there is no flashing light, the camera just turns off. Problem seems to go away after removing the battery for a few seconds. The camera works fine for a bit, but the issue re-occurs (seemingly randomly). Any thoughts before I contact Canon?
  • Panic Pandemic Jan 16, 2009
    Actually, I have the same problem. I bought the camera just two weeks ago and suddenly it won't turn on and the blue light is flashing. I've never tried to transfer images so I can't see why that would be the problem and the screen doesn't work either... I tried the display button and it won't show. The menu comes up and I can review images but the main screen won't work.
  • barry6386 May 11, 2010
    Look on page 148 of the manual. The camera is trying to transfer theĀ imagesĀ to a computer. The blue light blinks while images are being transfered and stays on after the transfer is complete. Do you have a cable connected to a computer? Is it possible you may have started a transfer and disconnected the cable before the transfer was complete and the camera is trying to finish this process? The auto-off feature turns off the camera after 30 seconds of inactivity. Go into the menu to change this. You may have to reset the camera to get it out of the transfer mode.
5 Suggested Answers
  • 6 Answers
SOURCE: Can't take good pictures with new Canon Rebel xsi
You will need to read the manual. I f you have a basic understanding of how ISO, shutterspeed & Aperture width combine to determine the 'right exposure.
Try this:
Set the camera to Av (aperture priority mode). Half press the shutter button and see the light meter indicator to see how well exposed your shot will be. For most cases you would be aiming for a value of 0 (properly exposed). The metering mode determines what part of the frame is used to compute the correct amount of light. For starters begin with pattern metering. Try and aim for a shutter speed of 1/125 or more if you are using the 17-55 mm EF-S f3/5-f5.6. Try and shoot at 40 mm F/5.6 (in Av mode this can be set by rotating the dial near the shutter button.
All the best
Posted on Apr 02, 2009
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
SOURCE: Flash won't open on Canon Rebel XSi?
The openning flash button only works on non automatic shooting modes.
On creative zone (automatic options with predefined options) the flash will rise automatically, based on the current exposure conditions. On "Flash Off" mode won't rise the flash ever.
Let me know, please if it solve the problem
Posted on Jul 19, 2009
  • 50 Answers
SOURCE: Hello Canon Rebel Xsi. I loaded all the
Its most likely a driver issue. Some can only be resolved by reloading the OS.
Posted on Sep 29, 2009
  • 58 Answers
SOURCE: Have Canon EOS Rebel Xsi Digital. Burning smell and flash busy.
Are you trying to use the flash when you are having the problem? Were you taking a lot of pictures with flash when the problem started? Rapid pictures with flash can melt the flash and capacitors in the camera. Also, a single drop of water rolling around inside the camera in the right place can do things like that. You can try taking pictures in bright sunlight so the camera will not try to use the flash and see if it will work normally, If it does than something is probably fried in the flash system. Bad thing is that if you smelled smoke something is most likely already fried and will have to be repaired by canon. Canons quality has been going down hill for several years now and they have a lot of quality problems. If the camera has been used very little, has never been abused, dropped or wet and not far out of warranty, try using google to see if this is a common problem and call canon and try to get them to repair it for free. If all else fails threaten to replace it with a Nikon assume pay to have barely used camera fixed.
Cannon EOS Rebel XS WB light
Have you not used it since dropping it in the river? You could try opening it up, giving it a rubbing alcohol bath and then putting it in a bag of rice overnight to set rid of any moisture.
Oct 22, 2012 | Canon EOS Rebel XSi Digital Camera
My canon rebel xsi won't take a picture with the .18-55m lens zoomed in
Clean the contacts on the lens? Your lens maybe defective need service?
Apr 08, 2012 | Canon EOS Rebel XSi Digital Camera
Canon XSi will not turn on
I think flash pcb or main pcb gone dead so its require to change. Take it to canon service centre.
Jul 31, 2010 | Canon EOS Rebel XSi Digital Camera
DOES THIS FLASH WORK ON CANON REBEL XSI?
Yes and no. It will work fine as a manual flash, putting the burden of figuring out correct exposure on your shoulders. It will work fine in the automatic modes on a Nikon camera.
Quantaray makes a Canon version of the flash which will work in the automatic modes on the Rebel XSi.
Jul 27, 2010 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Canon EOS Rebel XSi pop up flash won't "pop down"
Do not Tape it down, If the flash is pooping up all the time take it to a good Camera repair shop to have the catch replaced. At the same Time you may consider getting a full service done.
Dec 26, 2009 | Canon EOS Rebel XSi Digital Camera
Canon Xsi will not read external flash.
The XSi is not weather sealed like the 580ex II and is suseptable to liquid damage. Most cameras will take a few sprinkles and won't have a problem, but if the liquid got into the main body it might have issues. The top of the camera around the hotshoe is particularly sensitive.
I would doubt it could be self repaired. Take it to a liscensed repairer to have it looked at.
Sep 22, 2009 | Canon EOS Rebel XSi Digital Camera
Flash won't open on Canon Rebel XSi? It has been working fine but yesterday I went to take a picture and the flash wouldn't open. It won't open on any setting and it won't open if I push the manual flash...
Jul 10, 2009 | Canon EOS Rebel XSi Digital Camera
Taking Pictures of a Sunrise or Sunset
In the mode option u select sunrise or sunset noe be carefull while taking the photo the direct sunrays should never hit on your lense get a shade above your lense now try to take the photo without flash
Jan 05, 2009 | Canon EOS Rebel XSi Digital Camera
Canon Digital Rebel XSi Digital Camera Logo
1,123 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
