Question about Acer AL1917W LCD Monitor
Acer moniter model AL1916
It will not turn on.... I push to turn on the green light will not lite up. I think the monitor is dead as a door nail.
  • Anonymous Oct 14, 2008
    Just so I know what I am dealing with.... As u know the green lite does not turn on when I hit power. All connections and cords are fine.
    When one plugs monitor in outlet will the green light light up even though it is not connected to puter?????
    Genius:
  • 1,124 Answers
Check the cables and the computer connection VGA outlet.
If doesn't work and your monitor is under warranty ACER will repair your monitor for free.
If not, the better option is get a new one instead of repair due the high cost.
Posted on Oct 14, 2008
I have an ACER AL1916 monitor. The screen is black and the power light is green and blinking. What does this mean?
not necessarily, its just not receiving signal from the computer check your video card that might be the culprit
Jun 26, 2014 | Acer AL1916W 19" LCD Monitor
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
I have an Acer AL1916 monitor and I turned it on like normal yesterday and it has now got a weird green tint all over.. I've gone into the settings of the monitor and played with the red, blue and green...
sounds like a cable problem, can you find another VGA cable to try, look at the cable ends carefully for bent pins.(they are easy to bend by accident) wiggle the blue VGA connector while its on, try both ends, I think when you push the button your pushing on the cable momentarily which causes the monitor to function properly, likely the connector on the back of the monitor. if this helps, please use the thumbs up for feedback. cheers
Aug 26, 2010 | Acer AL1916B 19" LCD Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
I have an acer monitor model #al1916 when I turn it on it sstays on about 5 second and shut back down
First, check all electrolytic capacitors and replace those which are blown or rounded. Next, if when it shuts down the green LED also turns off, then
on the controller PCB there's tiny transistor-like chip U406. Remove it from the board and try to turn the monitor on. That's reset circuit, you may live without it.
Sep 05, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916 will show no picter, green light is on. What's wrong?
Try checking the setup of your computer for this issue (CMOS) check if the dual sreen option is enabled
Nov 16, 2008 | Acer AL1914 19" LCD Monitor
My Acer LCD AL1711 went off after seconds of turning on.
This monitor has "back lights" that are essentially like flourescent lights. These are high voltage lights and can easily fail. since you are getting some light initially, I would suspect a defective part that heats up a bit right away and then fails. I would try to replace the entire backlight board. This is the small board on the side (usually).
Dan
Mar 27, 2008 | Acer AL1711BM (Black) 17" LCD Monitor
Monitor is dead (black)
ask to moniter service technition
thanks
prasanna
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor won't turn on.
it something that is defect in the power mian board. Try to seach any buldging capacitor. that might have problem you.
Nov 23, 2007 | Acer AL1916B 19" LCD Monitor
Acer AL1917W LCD Monitor Logo
259 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
