Question about Brother SE-270D Computerized Sewing Machine
Need timing instruction for brother SE270d
Bobbin thread is wrapping arount the bobbin case.
    Problem Solver:
  • 5 Answers
Your needle thread lock on the bottom of your fabric and your bobbin thread locks on top. If you are getting jamming in the bobbin it is caused by the needle thread. Thread your machine with the presser foot up this will ensure thread going between tension disks.
Posted on Oct 27, 2008
Keep the thread from collecting on the arm that holds the bobbin case in? My Brother LB-6800 sews quilts, and embroiders great until yesterday, The thread wraps around this small arm every time now.
Try taking the bobbin case out and re-insert. It sounds like the case that holds the bobbin is not inserted correctly. You might also try checking to be sure that the needle is inserted properly. Sometimes the needle gets loose and drops down too low. unscrew, push the needle up as far as it will go, then tighten the screw.
Jan 24, 2015 | Brother LB-6800PRW Project Runway Limited...
I have a Brother SE270D and my top thread won't pick up my bobbin thread
Replace the needle with a Schmetz needle. If that doesn't work you need to get it serviced
Feb 21, 2014 | Brother 98-Stitch Computerized Sewing &...
Brother innov-is cs8080. Tangles underneath all the time Sometimes top thread wraps around the shuttle. Will not move forward. Have cleaned shuttle and changed spool but still not difference. Could...
Check your bobbin threading tension (is bobbin thread loose on bobbin?); check needle thread tension (does it snag or jump when feeding?)
Be sure bobbin case, etc. is properly installed in shuttle housing.
Aug 29, 2013 | Brother Sewing Machines
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
I can only get a small amount of thread wound on the bobbin.It stops and wont take any more. The bobbin case keeps moving & I cant get it back in correct place
I assume you are placing the bobbin at the TOP of the machine, then wrapping the end of the thread several times around the bobbin in a counter-clockwise motion?
Have you made sure to "scoot" the empty bobbin next to the bobbin bar to the right? Is the thread going from your spool, directly TO the bobbin? Because it is supposed to wrap around the tension "nut" (where you start to thread your machine) before going to the bobbin.
Apr 24, 2010 | Brother XL-2230 Mechanical Sewing Machine
Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Jun 30, 2009 | Sewing Machines
Cannot thread bobbin
If I remember correctly this machine has a little arm in the bobbin case area. You will need to open the slide plate, move that arm towards the middle of the bobbin. Thread your machine as normal, take the thread going through the needle eye and wrap it around the thumb screw a couple times, then start "sewing" your bobbin should begin filling, once started, you can release the thread wrapped around the thumbscrew. Once filled, you simply close the slide plate and that moves the arm back into place and start sewing.
Dec 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
Brother se270d
tighten the tension on the bobbin thread. or you are using the wrong size bobbin spool.
Nov 10, 2008 | Brother Sewing Machines
Brother SE270D
there is also a single screw on the bottom of the machine as well as one behind the bobbin winder, the last 'hidden" one is on the back side of the machine behind what woudl be the reverse button.
Jan 12, 2008 | Brother SE-270D Computerized Sewing...
Adjusting Bobbin Tension
I looked forever to find this darn green bobbin screw. Around the opening for your bobbin is a plastic cover. If you slide it forward it will pop right off. Once you remove this, the bobbin case will lift right out. On the front you will see your green screw for adjusting your bobbin tension.
Dec 28, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
248 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
