Question about Nintendo DS Lite Console
Rebuild power problems
I have rebuilt a couple of DS Lites but I have one that will not power up after the new housing was installed. It will blink when the power switch is turned on and nothing else. Is there any connections that must touch in order to it power up. Also, the top screen seem not to work as well. I have changed the screen but still no luck. Is there something I'm missing.
  • docxpd8 Oct 14, 2008
    I just redid two and have the same problem.. I can't figure it out for the life of me...
  • groundsforfu Oct 17, 2008
    It worked! Now the bottom screen is dimmer than before. Then I find my son broke of the power switch. Lucky I have two more main board to work from. I just can't win!
No insulation on bottom screen shorts out board
Posted on Oct 24, 2008
  • 4 Answers
I figured it out... make SURE that the ribbon cable from the upper screen is up into the connector as far as it can go... When I redid both of mine they both had this problem. I've since researched it more, and found this to be a problem (which makes sense as I tried to turn it on w/o the top screen connected as well and it did the same exact thing)...
Make sure that the black tabs on the cable as up touching (well almost) the white connector before you push down the black clip thing that holds it in place. Once you get it connected right, it should work for you (it did on two of mine)...
Posted on Oct 17, 2008
  • docxpd8 Oct 25, 2008
    insulation? On both of the ones I've rebuilt I've never seen any sort of insulation. On the three that I've had with this problem, the fix has been to properly seat the ribbon cable from the top screen into the bottom plug. After that, they work fine.
Electric start simplicity starter turned over for a couple of turns now won't turn over
Same thing happened to me.. I took off carburator and rebuilt it with a 20 Dollar seal and jet rebuild kit. i found all gaskets worn out. all tiny fuel inlets clogged....started first pull after and videos on rebuild on youtube make it too simple!
Jan 03, 2014 | Tecumseh Snowblower Snow Blower Starter...
The reverse went out in the transmission then later the rest of the gears went out
Unfortunately, these vehicles are known to have transmission problems. You'll need a rebuild, or you'll have to buy a rebuilt or new transmission and install it.
I recommend going with a fresh rebuild or buying a rebuilt/new transmission. Junkyard or "used" transmissions from these vehicles are prone to the same problems that yours is currently having. Most rebuilders such as Jasper will "improve" the design of their rebuilt transmissions to prevent known internal problems from happening again, and the other upside is they have a warranty!
Jul 02, 2011 | 1997 Dodge Caravan
Doesn't shift and shavings are in the pan.
Having owned a Trans Repair Shop years ago.
The rebuild manual---ATSG Manuals. Avail on their website or locally at a Trans Parts Supply house. Ask a local trans shop where they get there parts and get it there.
The fact you have shavings in the pan. The ONLY answer, is to pull the trans and take it to a Trans Shop and have it rebuilt. Then install a rebuilt converter and add a quart of fluid, before installing the converter.
You do what is called an over the counter. Your bring in the trans,they rebuild it in a couple days with all the latest updates. That is the least expensive way to go.
If they pull it, you surely will have things broken and pieces and parts missing when you get it back.
Aug 01, 2010 | 2000 Dodge Durango
Harsh shift points, delayed shift points, mushy power. tranny rebuilt at 36900. i am original owner, all highway miles, mature driver. tranny been sluggish ever since Massey Yardley rebuilt it, never was...
I don't have a solution but here's a couple of thoughts.
1. What were the problems that caused the tranny to be rebuilt at 36900? Were those problems similar to what you are experiencing now?
2. Did they rebuild your transmission or drop in another rebuilt one?
3. If you are still under warranty (I don't know when it was rebuilt), I would hustle back there and complain. In fact I'd do that even if it's not under warranty.
Mar 09, 2010 | 2007 Chrysler Town & Country LX New Cars
Nintendo dsi screens show no signs of power, but blue light is on?
your ds is completley broke you either have to go to a gamestore like gamestop,ebash u know those places to get it fixed or buy a new one.But most places dont sell ds lites anymore so youl have to buy a dsi or get your ds fixed somewhere
Feb 20, 2010 | Nintendo DS Lite Console
Trouble with tv coming on to long and new bulb didn't work
Is the lamp light blinking twice every 5 seconds or once every 5. Once every 5 sec. lamp failure,...twice every 5 sec.. ballast or thermal fuse. The ballast is discontinued and must be rebuilt or purchased used,.....try Ebay. NO TV REPAIR SHOP IS GOING TO HAVE THE BALLAST! They may be prudent enough to check into and find the rebuild kit for the ballast. FYI a rebuilt ballast costs around $175.00 ,....the rebuild kit costs anywhere from $12.00-$55.00
Jan 06, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Nintendo DS will not power off
let the power run out or send it to the repair shop for a week
Jul 08, 2009 | Nintendo DS Lite Console
Chevy TH350 trans problem
if you just had it rebuilt should ba a warranty if is was im sure you wouldnt be on here asking so did you install new torque converter when the trans was rebuilt? check the trans filter not clogged how long did it run after the rebuild or did you install it yourself after the rebuild and it doesnt work ? let me just say the torque converter should always be replaced with the transmission new or rebuilt and when the transmission is being installed you have to make absolutely sure the converter is all the way back on the trans if not you will damage the front pump on trans and would need to replace it .
Mar 23, 2009 | 1985 Chevrolet Nova
My action replay has no games and wont add new ones
first can you awnser one of my questions? how do u put cheats on ds lites? but for now. i will tell you if you tell me ok. well sorry but i think you need a new one! so now pleeeeeeeeeese tell me how to put cheats on ds lites coz i really need someone to awnser mine.my problem is called cheats a no no so please awnser it as soon as you can ok.
Jan 22, 2009 | Nintendo DS Lite Console
Green light flashes on then off and we still get no power
I had the Same problem with one of my DS lites .
It turns out it was the F2 Fuse on the mainboard.
You have to solder over the fuse bypassing it.
If you need any help or want some else to do it
shoot me an email at
herbstnbel@yahoo.com
Apr 13, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
79 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
