D3dx9_29.dllThis is because you are missing a file.Step 1. You can download d3dx9_29-dllStep 2. Paste this file into your system32 and system folder. Also put it in your syswowStep 3. Navigate to your System32(32Bit OS) or SyWOW64(64Bit OS) Folder.Note: The location of System32 or SyWOW64 isC:Windows\System32 (If you are using 32Bit Windows))C:\Windows\SysWOW64 (if you are using 64Bit Windows)Step 4.Paste the d3dx9_29.dll into this folder.Step 5.Run the game. It might work now.
The missing dll SoundMAX.dll is the dynamic link library module of Staccato Systems SynthCore 3 Library software program.
The dll file as well as the included Staccato Systems SynthCore 3 Library program is produced by Staccato Systems.
SoundMAX.dll is an important component for the program and in the case it is corrupt or not found you can get Windows problem warnings similar to; "SoundMAX.dll is deleted" or "Staccato Systems SynthCore 3 Library failed to start because SoundMAX.dll is not found".
To fix the error, you need to replace the corrupted or missing SoundMAX.dll file with a working one.
The current version of dll file available on our site is 3.0.0.0 with a size of 1008 kb.
You may download the file for legally licensed software only.
You can download SoundMAX.dll for free by clicking the link below.
After you download the file, unzip it to Windows system directory ("Windows/System32" for
Windows XP, Vista, Windows 7). You can use Winzip or Winrar to extract files.
Press "Start" and select "Run".
Type CMD and press Enter.
Type regsvr32 *dllfilename* and press enter again.
Download SoundMAX.dll v3.0.0.0
Please note : No guarantees or warranties are given or implied.
Please download and install the file at your own risk.
Always take a backup of the original file in case something goes wrong
hope this helps
