My HP pavilion dv2000 laptop makes loud beeps when I try to turn it on, and there is a black screen... what's going on?
  • 4 more comments
  • zoltans Oct 23, 2008
    Hy,
    My problem is I have a HP Pavilion DV2000 laptop and the don't startup only beeping 1 long beep and then 2 short beep. Pleasa give me an advise.
    Thanks.
  • jeremy__gree Oct 25, 2008
    My HP pavillion sounds one long beep followed by two shorter beeps, and has a black screen. The reboot disk doesnt work either. Sometimes when I keep turning the laptop off and on again it works, however when I turn it off the same problem arises.
    Please help!
  • Anonymous Oct 29, 2008
    1 long 2 short beep
  • Anonymous Nov 11, 2008
    i have the same problem and also the same sequence of beeping (on beep the two consequtive beeps)
  • Anonymous Nov 24, 2008
    Same issue HP Pavillion dv2000 laptop, did a restart after a software upgrade and beeep pause then two quick beeps.
    If I leave it shut off for a while it starts up either on safe mode or normal.
    Is this a heat issue as it "gets better" when it is shut off?
    Ken
  • Anonymous Dec 20, 2008
    I;m experiencing the same problem. But on keeping the laptop switched on for about 15 minutes , it starts up without the beeps.
Video ic dry solder
Posted on Nov 09, 2008
    Genius:
  • 1,124 Answers
  1. Computer beeps irregularly when the computer is turned on.
  2. Computer turns on but does not boot.
Note: Not all computers have beep codes, some of the newer computers have LED's that light up that indicate the error or have a sound file to indicate the error.
Cause: This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Identify beep code If you are receiving a sequence of beeps, these beep codes are meant as a method of quickly identifying what computer component is failing or bad.
The usually problems are related to: memory, video, keyboard or some similar hardware issue. Let me know your bios name and your beep sequence (short, long and quantity of beeps) and i will tell you which problem are you having in your computer.
Thank you for using FIXYA
Don't forget to rate my help, have a great day!
Pablo :-)
Posted on Oct 14, 2008
My HP Pavilion dv2000 turns on, but screen is black
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000 would not start up, black screen
try to re install first the software or program then observe if the same problem,, check the lcd inverter...
Jun 07, 2009 | HP Pavillion ZV6000 Notebook
HP pavilion dv2000 hangs with startup screen and when i do force shut down it gives beeps until i remove the battery and the the light is keep blinking on my laptop
hello..i think their is the problem hardware on the unit..try to remove the memory and try to clean or try to replace..thanks...and Good Luck..^_^
May 13, 2009 | Dell Latitude D600 Notebook
HP dv2000 gone dead
the problem occord when the battary charge full somtimes... try to switch on the laptop with battary power (if u getting the beep its k) wait for 10min and swith off the lap n turn it on.. this may work some laptops... when the battary get 100% charge the error beep will *** up... try 2 turn on the lap above 80%....
thanks
Mar 30, 2009 | HP Pavilion dv2000t Notebook
Hp pavilion dv2000 no lcd dispaly
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
Sep 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP Pavilion DV2000
first replace the inverter to correct the lighting problem ok. then move to the other problem both can be recovered from
so ebay dv2000 lcd inverter buy it get a screw driver link me bakerandre2000@yahoo.com
Apr 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
633 people viewed this question
David Payne
David Payne
