Question about Dell Latitude D600 Notebook
Computer what key do hit to get a laptop to go on a tv
  • Dell Master
  • 19,396 Answers
Depends on the laptop, some laptop is automatic, on dell see here
Dell laptop to tv?
I quote: "If you have S-Video (which u supose to have) then plug it in to your laptop and TV. Then go display properties->settings->advanced->displays. There u'll see three things: PC, laptop and TV, turn on the button on tv and apply it. This is basically it, unless you want to make some changes in properties, like make an extension for your monitor."
Posted on Oct 14, 2008
No signal from laptop to tv
Did you take the tv's remote and Select Input so the tv will know where to receive the signal? Press Select Input on the remote then select PC or Computer so the tv will know the signal is coming from the laptop.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 24, 2012 | Dell Latitude D630 Intel Core 2 Duo T7250...
How to connect my dell latitude laptop to my symphonic tv via s-video cable
Run the S-Video cable from the laptop to the tv. Take the tv's remote control and hit the Select Input button. Select S-Video or PC as your input source. Reboot the laptop and the video might show automatically.
May 23, 2012 | Dell Latitude D610 Laptop Computer -...
Connecting Eee pc laptop using xp to my tv with vga
Connect the VGA cable to the laptop and to the tv. On the TV take your remote and go to Select Input then select (PC or Computer or VGA just depends on your TV). if the image is not on your tv, reboot the laptop.
After rebooting if the image is not on the tv, try the steps below.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) located at the lower left portion of the keyboard + the correct F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 09, 2012 | Acer Aspire One AOD150-1165 Notebook
Hook gateway intel n450 to flat screen television
You'll need a cable that will connect from the computer to the tv. The easiest way is if you get a cable that will have the same type of connection for both the tv and the laptop. Otherwise you will need to have an adapter that will go between the two.
Once you have them connected by a cable then turn the tv on and select the input (source) which in most cases will be PC or Computer or HDMI etc. Boot the laptop and the image should appear on the tv. If not you will have to Press and Hold the FN function key near the bottom left on the keyboard then hit the F1 thru F12 key that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display.
May 04, 2012 | Gateway Netbook N450
Output to tv
May 04, 2012 | Fujitsu Siemens LifeBook® C1410 PC...
No video signal vga laptop to tv
Make sure you have the TV's input set to PC or Computer to receive the signal from the VGA.
Make sure the connections are snug on the computer and on the tv.
Reboot the computer and see if it automatically starts the display on the tv. If not, there are a sequence of keys that you can press to toggle the display between the tv and the computer.
Normally to toggle the display you will have to Press and Hold the FN function key located at the bottom left portion of your keyboard and then hit the corresponding key (F1 thru F12) that toggles the display. The correct F1 thru F12 key to hit will have the CRT/LCD on it or it might have the icon of a display.
Apr 22, 2012 | Toshiba Computers & Internet
Connect to tv
Make sure you have selected the correct input on the TV. Normally you have to tell the tv where the video input is coming from (Computer, PC, HDMI, etc).
Make sure you have the connections right and snug on both the tv and the computer.
Reboot the computer and see if the video appears, if not there are keystrokes you can hit that toggles the display between the TV and the computer. Normally you would Press and Hold the FN function key on the lower left portion of your keyboard then hit the key (F1 thru F12) that toggles the display. The correct F1 thru F12 key will have LCD/CRT on it or it might show the icon of a display.
Apr 21, 2012 | Computers & Internet
How to connect to tv
Depends on what type of ports your Computer has and what type of ports your TV has. The easiest connection is to try to connect using the ports that they both have. Otherwise, if they have different ports then you will need some type of converter that goes between the two of them to make them communicate.
Most computers have a VGA port, does the TV have a VGA Port? New computers have a HDMI port, does the TV have a HDMI Port? If so you the connections that are alike or you will need a converter.
Once you have them connected, you just have to select the Input on the TV. Most times if you use VGA then you select PC or Computer as the input. There should be an HDMI input selection if you use HDMI connections.
Reboot the computer and the display might appear on the tv. If not you will have to hit some keystrokes to toggle the display between the computer and the tv. Most times on the computer you will hit the FN function key and one of the F1 thru F12 keys that controls the display on an external. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display. Press and Hold the FN function key then hit the correct Function key (F1 thru F12) that toggles the display.
Apr 07, 2012 | Archos 70 android tablet Notebook
How to connect la toshiba qosmio f25 av205 to a tv
The computer and the TV will both need to have the same type of connection ports to make it simple. Otherwise you will need some type of adapters that changes or go between the two to make it work. Once you have them both connected, you will have to tell your tv that your Computer is now the input source (sometimes there will be an input for Computer, PC , etc.). On the computer, sometimes you might have to hit the FN function key and one of the F1 thru F12 keys to make the display appear on the tv. The correct F1 thru F12 key to press will either have CRT/LCD on it or it will have the image of a display on it. Press and Hold the FN function key then hit the correct F1 thru F12 key to display the image on the tv.
Mar 30, 2012 | Computers & Internet
ACER 5920g needs to stay on when lid closed
Plug first you computer o rather laptop to your TV with the right cable then right click to your desktop. Select properties then select settings then in the display drop down box choose number two click apply and hit ok.
Then before you close the lid...hit FN (color blue key) then hit f5....it will switch to your LCD to your TV. Enjoy.
Jun 05, 2010 | Acer Aspire 5920-6335 Laptop
Dell Latitude D600 Notebook Logo
41 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
