Question about Riso RZ220 Duplicator
Riso 1610 How do I reset the counter on this machine?
    Problem Solver:
  • 5 Answers
Cant change meter....
Posted on Feb 09, 2009
  • 30 yrs Feb 09, 2009
    sorry ment you cant .....have to change meter
Riso cr 1610 error code E-22
The E error code indicates that it is a logic or electronic failure and will requires a service person to service it. Sorry I couldn't locate anything more helpful.
Have a great day.
Jul 08, 2011 | Office Equipment & Supplies
Pulled drum out and now it's stuck outside the machine Risograph CR1630/1610
Hello
It seems as if the machine was not in the home position when the drum was pulled out.
The pressure roller is in the up position stopping the drum from entering.
To reset the pressure roller, you will have to remove the back cover, behind the power supply you will see a arm with a heavy spring on it. pull the arm up until it clips into the solenoid.
Once the preasure roller is back down look into the machine, there is a gear with 2 holes in it.
The hole on the left must be in line with the hole in the frame, the hole on the right on the gear must not line up to any holes but show to the exit side on the machine.
I hope this helps you
Regards
Apr 27, 2011 | Riso Office Equipment & Supplies
My RISO MZ770E gives error code "T17-020" Any Help would be appreciated
Error T17-020 means: The solenoid counter is not connected.
Hints: Check connection. Reconnect. Change counter.
Feb 17, 2011 | Riso RZ220 Duplicator
RISO 1610. Start light is blinking. Drum release
Friend,this code refers to switches cover:
can cover the trash (disposal box) that has two switches, magazine master.Tente verify that the drum is in position for opening.
Apr 09, 2010 | Riso Office Equipment & Supplies
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Feb 13, 2010 | Sharp AL 1631 Copier
Riso cr 1610
You will have to select corect machine model in service mode 200 , nomaly it is d but you will have to select between 1 and f to find the corect setting or just make sure that your cable is connected corectly
Nov 12, 2008 | Riso RZ220 Duplicator
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Riso 1610 code e-07
press the reset button
Sep 04, 2008 | Riso RZ220 Duplicator
129 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
