Janitrol (goodman) GMS9. Two years old. When thermostat is set low the ICM diagnostic LED is continuous on ("no signal from thermostat"), when thermostat is turned up then LED gives 3 flashes. Manual says that 3 flashes means "Pressure switch circuit not closed. Induced draft blower is operating", however the ID-Blower is NOT running. I ran a 110Volt wire directly to the ID-Blower to see if it runs independent of the control and it does run. I drew vacuum on both pressure switches and they do close and open ok. The switches also operated when I ran the blower with direct wire. I checked the condensate drain, intake and flue, no blockage, but I'm sure the only reason it is giving the "pressure switch" related error is that the blower isn't running therefore the switches can't close. I checked all wiring for thermostat and checked all connectors for tight connection, check for good electrical grounding at all ground wires. I installed a new thermostat but no change. I checked the voltage going to the ID-blower from the control module when first powering up the unit and before the fault lights register and it is only seeing about 9 volts from the controller. Is this likely a fault in the Integrated control module causing the ID-Blower to fail to turn on? Thanks.
  • wcraighamilt Jan 15, 2009
    I'm having the same problem. Mine is also two years old...coincidence? After bypassing the pressure switch it will work, but still not as consistently as it should. It was 20 degrees outside today and when i returned home from work it was 51 inside with the tstat set for 68.
    Novelist:
  • 124 Answers
Bad board . replace it .
Posted on Oct 19, 2008
What's wrong with my furnace?
The relay for the motor is stuck or the points inside the relay are arced closed. Replace the relay.
Apr 26, 2016 | Goodman Janitrol Amana Goodman Janitrol...
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
My Goodman GMS9/GCS9 Gas-Fired Furnace is not working.?
Check all safety switches on door. Make sure the main breaker in fuse box is on and well as main switch on furnace. Please ad more details. New install, just quit working? How old....
Oct 27, 2013 | Goodman GMS90703BXA Heater
I have a 6 year old Goodman "GPG10481151A" single
try turning the t-stat all the way down then kill electricity to unit wait ten min and turn everything back on, see if this helps. let me know.
Mar 02, 2011 | Amana Heating & Cooling
GOODMAN GMS9 limit switch
check the temp on the switch.Any switch will work as long as it has the same temp setting.
Oct 30, 2009 | Goodman GMS90703BXA Heater
I have outside Goodman-Janitrol furnace and air unit and
two things to try first to get you pointed in the right direction. First disconnect the R or RH wire from the T-Stat. If the furnace turns off (Stops firing w/ fan to turn offabout 90 sec. later) then you more than likely have a bad Thermistat. If it continues to run Pull the R wire from the Furnace circuit board. put door back on furnace if it stops you have a short in the wire. Still Running? Most likely a bad curcuit board. Hope this helps.
Oct 12, 2009 | Goodman GMS90703BXA Heater
Furnace won't turn on....
jump out thermostat or try jumping out the pressure switch
Feb 23, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
413 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
