My 19 samsung computer lcd monitor problem
When i turn on the computer the power light on the lcd monitor flashes like it's off or on standby. I've tried disconnecting everything and hooking it back up. Anyone have this problem or know how to fix .
samsung syncmaster 940bf
  • 1 more comment
  • Woop_Ass17 Oct 14, 2008
    Not an amber light jsut the blue light flashes like it's in standby no amber light shows up
    kk thx i will try that
  • classiccarpe Jan 08, 2009
    I was having a similar problem with my new Samsung. Sometimes it seemed to work fine, other times it did the flashing on and off thing. It seems that my refresh rate might have been the problem. I had it set on 75 htrz. I changed it to 60 and so far it seems to be doing ok. I don't know if it's a problem with this monitor or what...
I had the same problem...apparently the Syncmasters have some caps that are known to go bad pretty often. They will show visible swelling on the top with the slits. If they are flat they are probably good. The 820uF was too hard to find so I used a 1000uF with the same voltage. I had two caps blown on two different monitors so be sure to check them all. Hope this helps. Check out pics on
Posted on Mar 31, 2009
  • 159 Answers
I repair quite a few models of monitors and in MOST cases when a monitor goes to sleep, the light becomes a steady dim amber color.
If they flash that is usually an indication the the powerboard is not putting out enough power to run the unit or there is a problem with the inverter board.
It will more than likely have to be opened up to determine the problem.
Posted on Oct 14, 2008
Samsung TFT 19 LCD no flashing red LED continues on replaced all caps
did you check the output dc voltage of the power supply if present. if ok, then doesn't turn on the problem is with in the main board.
Oct 10, 2012 | Computers & Internet
VL1919 blue light flashes continuously, monitor does not turn on. . . even after DAYS of flashing. : (
That is the problem with the standby section of the power supply. A continuous flashing indicate a shorted component usually a small diode.
May 24, 2011 | Princeton Digital VL1916 19" LCD Monitor
Monitor will not turn on. i've tried the remote with no luck. all i get is beeping and a flashing red power light.
The Power supply board of the Television is dead.Tries Websites, to buy a reburbish power supply board for the replacement.
Hope this will help out
May 06, 2011 | Samsung LN-T1953H 19 in. LCD HDTV
When my computer shuts down, the Monitor flashing green light keeps flashing. My problem is that I can not turn the Monitor "on" light off.
its a default feature. playing with the fromt pannel may cause an early filure or malfunction.
to get if off, switch off it from the power source. or remove the power cable from back.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
can you see that a capicitor 820/10v is pluked ? replace it.
Feb 21, 2010 | Samsung SyncMaster 932B LCD Monitor
My 19" flatscreen monitor flashes on a blank screen and the power button light flashes on and off blue, no picture.
Problem in Your monitor VGA cable no horizental or Vertical signal.So it is not active standby mode.Check signal or VGA cable on not adjust properly CPU.or any other device.May be VGA cable was broken.Replace it.If you are not replace the part so you can get help any service technician.
Dec 27, 2009 | Soyo 19" LCD Flat Panel Monitor
Samsung lcd monitor power button flashes and wont turn on or off
I have the same exact problem. The monitor seemed fine yesterday. Today, the power button light just flashes on and off, with nothing on the display.
Dec 05, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Moniter very lightly flashing
Problem was not solved. I am returning to Samsung. Thanks.
Jan 05, 2009 | X2Gen MG19MY 19" LCD Monitor
Computers & Internet Logo
910 people viewed this question
David Payne
David Payne
