Home | Bunn | BT10B Coffee Maker | Bunn blows fuses
Bunn BT10B Coffee Maker
Problem for Bunn BT10B Coffee Maker
Bunn blows fuses
By joy50 on Oct 14, 2008
bunn blows fuses
Same Problem
Mar 19, 2009
-   I have the same problem with my bunn coffee maker blowing fuses, and this is the second bunn that I have had that has had the same problem. This coffee maker is only about 4 to 6 months old. I don't understand because my daughters have been using bunn coffee makers for years and they never have a problem with their coffee makers. Can anyone help?-   Darlabug
Best Solution
posted on Feb 11, 2009
Very Helpful)
furnoptn
Rank: Guru
Rating: 89%, 68 votes
This is usually caused by the tray where you pour in the water leaking where it mounts down to the tank. it's probably cracked just enough to allow water to seep out, crossing wires on top of the tank, causing a dead short. There is also a seal that goes between the pour-in tray and the tank that sometimes starts to leak. This tray can be replaced if you can find a used machine that doesn't have the same problem. Before you buy one, though, you should take the top of your brewer off, remove the pour-in tray (careful - they get brittle over time) and look on the top of the tank for signs of water seepage. If there are no signs, then your heating element is most likely blown.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Bunn BT10B Coffee Maker
Questions and Unsolved Problems for Bunn BT10B Coffee Maker
Do you recommend Bunn BT10B Coffee Maker?
Answer
Answer
the part you pour the water in leakshow do i fix or get new part
Answer
Can a replacement decanter be obtained???for a bt10b
Answer
I'm helping a friend fix heater problem with the Bunn Model BT10-B. I've taken it apart. Surprised... (More)
Answer
I have a bt10-b.A few weeks ago along with coffee it put out a nasty brown liquid that I could not... (More)
Answer
i am moving and need to empty the water out of my bunn how do i do that?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bunn BT10B Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
