Question about Whirlpool Duet GHW9150P Front Load Washer
Spots on the clothes
I wash my shirts and items as specified with liquid Tide, and a diluted solution of Downey, but most of the cotton shirts come out with spots all over them.
  • sheenatorres Oct 23, 2008
    OMG! Me too. Do the spots look like they are oil spots? They have a brownish color? I purchased my washer in October of '07. Within in a month I was noticing the spots. I have 3 children and between my husband, my children, and myself, I have had hundreds and hundreds of dollars of clothes ruined. I cant just go out and replace them either. What can I do? I do use Bounce dryer sheets, but how do those leave spots? Any help, PLEASE.
Thank you GCMP. Thta was the problem even though Whirlpool refuses to acknowledge it. Thankfully Lowes is a stand up company and they voluntered to replace my washer with a GE washer instead. I thank you again.
Posted on Oct 29, 2008
    Problem Solver:
  • 5 Answers
I think Bounce would lose alot of money if their products caused dammage to clothes, it's nothing to do with detergents or anything in the drum apart from you clothes. The bearing seal at the back of the drum has failed (common problem) the oil that lubricates the bearings is now leaking onto the clothes as water flushes it out.
Open the door and pull the inner drum towards you while holding the outer drum in place, move it side to side also if you can, if there is virtually zero movement then your bearings are okay which is good because faulty bearings can cause alot of other dammage.
Usually you cannot get the bearing seal seperately as it comes in a kit with the bearings. This could be reasonably costly because the drum has to be removed to get at the seals and as a standard procedure the bearings are replaced as they have been compromised by the seal wearing away and water getting in.
Posted on Oct 23, 2008
IF YOU ARE USING BOUNCE IN THE DRYER ON HIGH HEAT IT WILL CAUSE SPOTS ON THE CLOTHES IT'S NOT THE WASHER.
Posted on Oct 15, 2008
I have a Kenmore series 600 washer which leaves white residue on laundry. I've tried using less detergent (only use liquid detergent) but it still happens. Using Tide detergent.
There are a lot of causes for that issue. Overloading, too much softener, bad drain pump, dirty drum, hard water are some of the more common ones.
Jan 11, 2017 | Kenmore Washing Machines
I just bought a defy top loader dtl 151 and it keeps tangling the clothes
Here are a few suggestions.
Sometimes too much water ( or not enough clothes) will result in tangled clothes.
Sometimes the types of clothes will tangle more easily than others.
( Thin cotton tee shirts or long cotton dresses might tangle easily. )
I might recommend you mix in some heavier and thicker items to help, such as towels or blue-jeans and see if that fixes the problem.
God bless your efforts.
Aug 22, 2016 | Washing Machines
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
How come my clothes don't smell fresh?
Not the machine, stop using liquid soap. put machine through a cleaning cycle using a product like affresh.
Oct 10, 2014 | Samsung WF337AA Front Load Washer
My Frigidaire FTF530FS Front Load Washer appears to be leaking oil and it is getting on my clothes
Hello Loree Grudem - This can be the result of the shaft bearing and seal. They may have become worn and the transmission oil is creeping up to get in your water. Once this happens, it gets on your clothes to cause staining. Or possibly you have a buildup of fabric softener that comes loose and puts a greasy like substance in your water and on your clothing. Once you put your clothes in the dryer and the old fabric softener melts you will see these spots. I suggest contacting a professional to move forward accurately.
Oct 09, 2012 | Frigidaire FTF530FS Front Load Washer
The smell of my laundry
Try putting one more sheet in the dryer as far as the Tide with Downey it`s propbably getting rinsed out when your washer goes through the rinse cycle.
Feb 20, 2010 | Whirlpool Dryers
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
Aug 31, 2009 | LG WM0642H
Tiny holes in the front of my t-shirts...
wow- my husband and kids were blaming me for putting holes in their shirts with bleach- tried to explain to them that i did nt use bleachon dk colors- will changing the tub help?
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spots on clothes
By spots I'm guessing that this is a permanent mark on the cloth. If that's the case, you are possibly putting concentrated liquid bleach into the machine...it is being added and causing the spots. Solution is to dilute the bleach or other concentrated cleaner. If you're adding it manually through a hopper...add it later in the cycle.
If the spots are black...you may have a bearing leak into the machine. Repair is a big job.
Dec 02, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
161 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
