Question about HP mx705 17" CRT Monitor
Brightness display comes on by itself and won't turn off
The brightness on-screen display automatically turns on, then it increases to it's max brightness, and can't be turned off. What is going on with it and is there anything I can do about it?
  • Anonymous Dec 13, 2008
    I have the same problem with the brightness display coming on by itself and not turning off.
    New Friend:
  • 62 Answers
1. Adjust the LOT screen preset.
2. Trace the G1 path , LOT to neck board. Sum times diode are capacitor problem.
3. LOT sarounds one 10Mf / 450 V capacitor bad
Posted on Oct 14, 2008
Screen not bright auto-brighness not working
To increase the brightness, either swipe up from the bottom to get the control panel, and increase the brightness there (slide the slider just below the 5 circles to the right) or go into Settings > Display and Brightness> Increase brightness using slider. You can also turn on the auto brightness from here if it is off, or turn it off if it is not working like you want it to.
May 13, 2016 | Apple iPhone Cell Phones
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
Power is on but no signal output to the screen
The following applies to Acer Laptops. You did not specify the brand of laptop you had. If your laptop is not Acer, the specific keys mentioned may be different and you should adjust accordingly.
Apr 04, 2011 | Computers & Internet
Shut down my Acer 2480 wrong by pressing the power button. Now it doesn't reboot or boot up. I tried to pressing F2 to reboot but it doesn't do anything. Any suggestions?
Look at the power indicator:
If it is not lit, no power is being supplied to the computer. If the computer has a battery, it may be low and unable to power the computer. Connect the AC adapter to recharge the battey pack and make sure the AC adapter is properly plugged into the computer and to the AC power outlet.
If the power indicator is lit, check if a non-bootable (non-system) disk or USB thumbdrive is in the computer. If so, remove it and press Ctrl + Alt + Del to restart the system.
Pressing F2 by itself is only used to enter the system's BIOS on startup. If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
Apr 03, 2011 | Computers & Internet
I have a advent m201 laptop . how do i turn the built in webcam on please
Try this
Function Keys Fn+F1 - Places the computer into sleep mode
Fn+F2 - Changes the (I-Powerxross) power settings
Fn+F3 - Switches display modes: LCD only, External monitor only, LCD+External Monitor
Fn+F4 - Turns Wireless LAN on/off
Fn+F5 - Switches OSD (on screen display) on/off
Fn+F6 - Turns the Touchpad on/off
Fn+F7 - Turns the Webcam on/off
Fn+F8 - Mute Sound
Fn+F9 - Reduces speaker volume
Fn+F10 - Increases speaker volume
Fn+F11 - Reduces the screen brightness
Fn+F12 - Increases the screen brightness
Fn+Esc - Toggles Bluetooth & 3G on/off (optional)
Thanks
Dec 30, 2010 | HP Pavilion dv6000z Notebook
Acura 2007 tsx with navigation in the auto day night mode the nav screen doesn't automatically change to the night setting how can i fix this?
Turn the display brightness knob (the one up by the speedometer) down. When the brightness knob is at max the navi will not go into night mode. This information is in the manual buried somewhere.
Apr 12, 2010 | 2007 Acura TSX
Monitor Contrast and Brightness Problem
service your monitor your monitors cadr is problem
Oct 02, 2009 | Proview PL19Wb Monitor
Philips 170s6fs monitor: OSD menu blocked
.well i had the same problem but my dad fixed it.
.he opened the monitor [like unscrew it.] and just clean it. brush it. and it will work fine.
if it didnt i dont know.
Dec 06, 2008 | Philips 170S6FS 17" LCD Monitor
HP mx705 17" CRT Monitor Logo
158 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
