Question about Canon Office Equipment & Supplies
Selphy DS810 printer. Error code 5100. Possible full waste ink absorber? I just replaced an empty ink tank. Can I fix this problem myself?
    Problem Solver:
  • 63 Answers
Did you hear a loud crunching sound from the printer before the error code 5100 was displayed?
1. You may need to send in the unit for service. Some Cannon Service offer temporary replacement unit while working on yours.
Checking and do-it-yourself inkjet printer repair is messy.
2. You can try check if the print head assembly (carriage) moves freely from left to right. Lubricate/clean if necessary (If your printer has one) check also the **** strip at the back of the carriage. This is a plastic film with multiple dark notch like mark. Clean with cotton swab and light solvent or isoprophyl alcohol.
If these does not solve your problem, guess your back to # 1.
Good luck and kind regards.
Posted on Oct 16, 2008
  • 4,472 Answers
How long have you owned the unit? This problem occurred after you changed the ink tank? Once I have more information I can assist you further.
Thanks,
Lee
Waste ink absorber for selphy DS810 photo printer is full, how do i replace it, and where can i buy another absorber? thanks!
I'm not sure if there are replaceable? If you looked in the user manual and if it dose not mention it, odds are it can not be replaced...
Sep 05, 2011 | Canon Office Equipment & Supplies
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Waste Ink Absorber Full: Can I fix this myself or do I need to take the printer in (or replace it?) If I can fix (or empty it), where is it and how do I access it?
Waste pad ink or waste ink absorber can be found inde the machine. Open the cover and you can see the plastic tank with foam, and replace the foam. goodluck
Jan 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Error code 5100- this keeps coming up when i turn on the printer and will not allow me do anything. Have tried plugging out and back in again, as per manual, but to no avail.
You may need to follow this support documentation from Canon: (please follow along to "Search" for your solution)
In the following page, type the question "error code 5100" and click the <Search> button.
Selphy DS810 Support and Service
Dec 20, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
MY Pixma IP90v has an error message waste tank full. Can I fix that myself or do I have to take to a repair station?
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
You should send it to service centre
Oct 31, 2009 | Canon PIXMA iP90v InkJet Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
5100 error code
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
old marine
old marine
