Question about Cannon Office Equipment & Supplies
I need to delete the software for a Cannon MP30 printer from my computer. I have Windows XP Home and the regular Microsoft program for removing it does not get the job done. I can not find the installation disc that came with the printer. How can I remove the uninstall the program for the Canon MP 30 printer?
    Genius:
  • 1,124 Answers
To remove your software go to >> Start >> Control panel >> Add/remove programs
If you did it already and your software is still in your computer do this:
1) Uninstall the printer,
2) Delete all the printer folders created during the last installation. (usually in folder "Program Files")
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
To get your software go to: www.canon.com
Support >> Sotware and drivers
And download form there your printer software
Posted on Oct 14, 2008
Why is my pc processing very slowly, how can I speed it up
Try not to run too many programs at one time, uninstall software that you do not use anymore, run CCleaner for keeping your computer clean, avoid installing too many fonts, delete your Internet history regularly or set it to only remember history for a week or less, make sure that your computer and your software has the latest updates, and use Antivirus to protect your computer.
Nov 02, 2011 | Microsoft Windows XP Home Edition
I want to remove n delete window genuine microsoft software
Exactly what Microsoft windows software do you want to delete? I assume you want to keep the operating sytem.
Click on Control Panel. In WIN7 click on Programs and choose which program to uninstall.
Similarly in WIN XP.
Why do you want to delete software? What problem is it causing? Go to Microsoft.com for assistance.
Jul 18, 2011 | Sport & Outdoor - Others
I am trying to get rid of the xp home security 2011 virus.
Manual Removal:
1. Press Ctrl+Alt+Del on keyboard to stop process associated to "XP Home Security 2011?. When Windows Task Manager opens, go to Processes Tab and find and end the following process:
(random characters).exe
2. You need to update your installed antivirus application to have the latest database.
3. Thoroughly scan the computer and any detected threats must be removed. If removal is prohibited, it is best to quarantine the infected item. Manually locating and deleting of malicious files should also be performed. Please see files below that are related to XP Home Security 2011 Virus.
4. Registry entries created by XP Home Security 2011 must also be remove from the Windows system. Please refer below for entries associated to the rogue program. [how to edit registry]
5. Exit registry editor.
6. Get rid of XP Home Security 2011 start-up entry by going to Start > Run, type msconfig on the "Open" dialog box. A windows containing System Configuration Utility will be launched. Go to Startup tab and uncheck the following Start-up item(s):
7. Click Apply and restart the computer.
XP Home Security 2011 Removal Tool:
In order to completely remove the threat from a computer, it is best to download and run Malwarebytes Anti-Malware. Sometimes, Trojans will block the downloading and installation of MBAM. If this happens, download it from a clean computer and rename the executable file before executing on the infected computer.
Using Portable SuperAntiSpyware:
To thoroughly clean a computer, it is best to do a separate scan of another security program so that other infected files not detected by anti-virus application can be remove as well. Download and run SuperAntiSpyware Portable Scanner.
Apr 06, 2011 | Computers & Internet
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Install XP, it hangs up with the message at the bottom ''Searching for previous versions of Microsoft Windows'' please help
You already have a previous xp on our computer. You need to first go to your control panel, then install or remove programs and delete the old xp, then reboot computer, now reinstall xp with new software.
Oct 18, 2009 | Microsoft Windows XP Professional with...
My AVG is conflicting with my installing Kaspersky.
you might not have uninstalled AVG .instead you could have deleted the AVG folder.
AVg components are still there in the registry.if you didnt uninstall it ,install AVG once more and uninstall it manually.
if its not working remove AVG components from registry
here are the instrucions:
To remove the AVG registry entries, open Registry Editor (Start-> Run-> Regedit). In the registry editor, navigate to the entries mentioned below,
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\AVG\Avg8
Right click on these entries and then delete them. If you are not comfortable about deleting registry entries, you can use a free registry cleaner. If you are using a 64 bit machine, then these are the entries to be removed.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AVG\Avg8
Once these entries are removed, Kaspersky installation will be completed normally. Alternatively you can also use the AVG cleaner or Kaspersky removal tool for AVG8.
Jul 21, 2009 | Microsoft Windows XP Home Edition
Generic host process for win32 services encountered
1. Uninstall KB873333 microsoft update (Control panel> Add\Remove program> check show hidden microsoft updates then uninstall it)
2. Scan the computer with free SuperAntiSpyware. download from http://www.superantispyware.com/download.html
3. To resolve this problem, follow these steps:
  1. Turn off the computer and the printer or the scanner.
  2. Disconnect the printer or the scanner from the computer.
  3. Restart the computer.
  4. Install the compatible drivers and software for the printer or the scanner, and then reconnect the printer or the scanner to the computer.
4.
931852 (http://support.microsoft.com/kb/931852/ ) Error messages when you start a Windows XP-based computer and then try to download Windows Updates 894391 (http://support.microsoft.com/kb/894391/ ) You receive a "Generic Host Process" error message after you start the computer, or DBCS attachment file names are not displayed in Rich Text e-mail messages 819017 (http://support.microsoft.com/kb/819017/ ) Long delay before files appear in My Computer in Windows XP
Nov 23, 2008 | Microsoft Windows XP Home Edition
Need to attach cannon printer to computer without the instal disc.
If you have Windows XP Home or Windows XP professional you will not require any cd. Turn on the printer and then connect the USB cable. You will get the Hardware wizard screen. Put a check mark on install the software automatically and your printer will be installed successfully and ready to use
Oct 07, 2008 | Cannon Office Equipment & Supplies
Kodak aio printer 5300/software problem
Greetings Jackie,
Sounds like you have a failed .netframework installation. This is a Microsoft feature, but is delivered during installation of Kodak software as well. To fix this, do the following.
1. Open the Control Panel.
2. Double-click Add / Remove Programs (Windows XP only).
3. Select Microsoft .NET Framework 2.0.
    IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove.
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
    1. Follow steps 1 - 4 above.
    2. Select Uninstall, and click Next.
      IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
    4. Perform a clean re-installation of the KODAK AiO Home Center software:
      a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
      NOTE: Do not disconnect your mouse or keyboard.
      b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
        i. In the Control Panel, select Add or Remove Programs (Windows XP).
        ii. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
          • Kodak EasyShare software
          • Kodak all-in-one printer software
          • Kodak EasyShare 5000 series all-in-one software
        iii. Click Change or Remove (Windows XP).
        iv. When the Install Wizard appears, click Next.
        v. Depending on the issue(s) you are experiencing, do the following:
          • If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
          • If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
        vi In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
        vii. In the Ready to remove the program window, click Next.
        viii. In the Uninstall Complete window, click Continue.
        ix. Restart the computer.
      c. Delete the files and folders that can interfere with the installation:
        • Printer folder in C:\Program Files\Kodak
        • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
        • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
        • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
      d. Run Disk Cleanup.
        i. Open My Computer.
        ii. Right-click Local Disk (C:) and select Properties.
        iii. Click the Disk Cleanup button.
        iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
        v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
        vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
      e. Shut down all background applications.
        i. Select Start > Run.
        ii. Type msconfig in the Open field, and click OK.
        iii. Select the Startup tab.
          IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
        iv. Click Disable All , then click OK .
        v. When prompted, restart the computer.
      f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
      g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
      h. Before restarting the computer again, turn on the background applications.
        ii. Type msconfig in the Open field and click OK.
        iv. Under Startup Items:
          - If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
          - If all background items were originally selected, click Enable All, and click OK.
      i. Restart the computer.
      Once restarted, you should be OK.If not call our 800 421 6699 and they will help further.
      Best Regards,
      Ron Baird - the friendly Kodak guy
Sep 18, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EasyShare 5300
Sorry to hear about your trouble. Since I am not sure of the details, let me offer a long review and suggestion. It may work for you, especially if the AiO software is not installing correctly.
If the KODAK AiO Home Center software fails to start or an error message appears, there may be a problem with the Microsoft .Net Framework 2.0 installation. To resolve this condition:
2. Double-click Add / Remove Programs (for Windows XP) or Programs and Features (for Windows Vista).
4. Click Change / Remove (for Windows XP) or Uninstall (for Windows Vista).
1. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
2. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
3. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
4. When the Install Wizard appears, click Next.
5. Depending on the issue(s) you are experiencing, do the following:
- If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
- If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
6 In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
c. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
i. Printer folder in C:\Program Files\Kodak
ii. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
iii. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
iv. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
ii. Eastman Kodak Company folder in C:\ProgramData
iii. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
Jan 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
