Transformer burned out - Heating & Cooling
  • meccie Nov 16, 2008
    I replaced the thermostat on my Carrier AC and evidently shorted out something probably the TRANSFORMER and now I have nothing going to the thermostat. If I have a transformer I cannnot locate it. I need to know where the transformer is and how it is wired.
    Thanks
  • meccie May 11, 2010
    I thought the same thing but I cannot find the fuse. By the way I did have a short at the thermostat.
    Problem Solver:
I found my problem it was a fuse. The hadest thing was finding where the fuse was located. I kept looking and taking apart until lo and behold it was in the unit inside behind the big plate. I replaced the fuse 5amp and every thing is ***** dodey. I hope some one gets some use from this article.
Posted on Nov 16, 2008
I took care of the problem. I think my unit is older than 10 yrs. and it did not have a fuse protection, but I installed a fuse and now it's protected. The problem was at the thermostat, for some strange reason the thermostat burned out. Well, it was not a strange reason, the friend who helped me cleaned the unit ...He shorted out the thermostat. So I went and got a new one and also a new transformer. The unit is up and running like new!
I thank everyone for their input...
Posted on Oct 15, 2008
  • 3 Answers
Usually if a tranformer burns out you have a short in the 24v side of the system. What type of system do you have? Most units built within the last 10 yrs should have some type of fuse protection.
Posted on Oct 14, 2008
How do I fix an ikea lamp with a burned out transformer.
go to an electrical whole sale business and see if there are transformers available that meet the specifications on the side of the original units and if so then consider getting them and have an accredited electrician change the plugs / sockets for transformers to burn out I suspect that the input voltage into the transformer is not as specified on the trans former and any transformers that you get will have to have the same primary voltage as wht is available at you place
Oct 30, 2015 | Computers & Internet
Why does the transformer get hot and burn up?
The only thing that would cause this is something in the circuit is pulling too much electricity through that transformer. So what is the transformer hooked to? Please post the make and model
Aug 07, 2015 | Heating & Cooling
Can the two transformers be hooked in parallel to service a 500 W zone?
If you are talking about low voltage light transformers, then answer is probably NO... but you could try it and see if it works... but I am almost certain that both transformers will probably burn out.
Output is 12 Volt AC... the transformer coils will probably burn out because the waveform from each transformer cannot be guaranteed to be the same.... even if both transformers are seemingly identical and plugged into same outlet.
For additional information, read transformer installation tips on following page.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
Power company transformers can be wired together in specific ways to produce 3-phase waveform, but these transformers are specifically engineered for the task. And the transformers do not combine the output (as you would be doing with yard transformer), instead each power company transformer produces 1 leg of power in a 3-leg power supply.
http://waterheatertimer.org/What-is-3-phase-electric.html#transformer
Gene
Water Heater Timers Save Money
Mar 14, 2015 | Hardware & Accessories
I have a 2.5oz popcorn machine, I plugged it 220v by mistake and it required 110v, the transformer connected to the motor burned out, is it possible to repair the transformer because I can't find a...
if the switches were turned on for heat and stir functions when wrong power was applied then im sure those functions were damaged as well it's just not apperant right now , are you sure it's a transformer you saw burned ? im not in the knowlege of this unit needing a transformer , could it possibly be a power conditioner thats burned , transformers have iron plates lamanated in many layers that are very noticable from the outside , power conditioners do not have layers or plates but are smooth and covered in metal ??
Jan 17, 2015 | Waring Popcorn Machines Pro Wpm25...
I have a HE265Ahumidifier it keep burning out transformer whats wrong
Hello, usually the transformer will burn up when the amp rating of the transformer is being exceded or if there is a short in the low voltage wiring
Dec 09, 2011 | Honeywell HE360A1027 Whole House...
My Flair smells like it is burning and the plates are making a loud sparking sound
What's burning is probably your high voltage transformer. When your glass plates get a crack in them, they will spark. You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 01, 2010 | Ecoquest Flair Air Purifier
Will a short/ground in the thermostat wires cause a model(-) HQA to burn up the 24 volt transformer
If the transformer wires are shorted together, this will burn up the transformer. Normally transformers on the LV side (24 volt) are not grounded, but the solenoids that they control could be grounded, and a t-stat wire that is unintentionally grounded could burn up the transformer, but its not likely.
Jul 09, 2009 | Ruud Heating & Cooling
Input Transformer 220 V
The more details you add, the better answer you'll get. For burned out transformers buy a new one with same power rating.
May 04, 2009 | Audio Players & Recorders
Foodsaver Profesional II heat strip transformer burned out.
The transformer can be found at a good wholesale electronics store, it is 12 volt and will register slightly higher with ohm meter. You can also use a 220 to 24 volt transformer.
Dec 04, 2008 | Food Processors
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
