Question about Garmin GPSMAP 76CS GPS Receiver
Blank Screen on Garmin E-Trex Vista
My Garmin E-trex Vista will have the screen go blank with the exception of one dark line down the center. It is somewhat random and it doesn't matter if I am running off the battery, plugged into the cigarette lighter or into the laptop. Sometimes it goes blank in a minute or two, other times in fifteen minutes. New batteries don't help.
Wayne i have the same problem with the screen going blank except 1 vertical dark line. my model is garmin gpsmap 76s
  • nootay Nov 03, 2008
    I have the same issue with my 76 s.
  • 3 Answers
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Posted on Oct 19, 2008
My garmin e trex vista keeps telling me acquiring satelite for 1 month now. What's the problem and how do I fix it?
have you tried moving it to another location?
does it have an internal or external antenna..either way give it a good view of the sky..
May 29, 2012 | Garmin GPS
Garmin e-trex Vista - blank screen
I would suggest that you contact Garmin for a replacement if you still have it under warranty. If your computer can still detect the Garmin when plugged in you might still be able to update the firmware but as you said it does not turn on then that would be a remote possiblity so it would be best to have it replaced if it is under warranty
Aug 19, 2008 | Garmin 010-00358-00 GPS Receiver
Window is filled with blue lines
BAD SCREEN cable connection. Your screen cable needs to be reseated. Better to take it to the professionals than toopen and attempt it yourself
Jun 30, 2009 | GPS
Trouble tunrning gps on with batterie mode
Solved my problem by buying another new model from garmin.The e'trex was great but I rather have a model with buttons on top and a larger screen so I orderd a gpsmap76cx. This e,trex I would of sold it but not with the problem I have with it.I will contac garmin support to see what they say.It,s a rebuilt model so I think the unit was sent back for a certain problem and even thou it was rebuilt the unit is problem cursed.Thanks for your time and I won't be spending another cent on this one.
May 28, 2009 | Garmin GPS
Display on my Garmin E-Trex Legend GPS
Sounds like the screen is shot and theres nothing really you can do to fix it, sorry :(
You can send it to Garmin for the flat rate repair fee of $79 dollars. I would recommend getting the new eTrex Legend H with the high sensitivity receiver if you want a similar model. It's sat reception will blow the prior version out of the water and has 24mb of memory rather than the 8mb it used to have.
Jan 19, 2009 | Garmin eTrex Legend GPS Receiver
Error message when downloading; No response. Check connection or
من مشکل ترا حل کرده نمی توانم کشاد خان
Jan 10, 2009 | Garmin eTrex Vista GPS Receiver
Screen goes blank except for a verticle streak
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Nov 03, 2008 | Garmin GPSMAP 76S GPS Receiver
If that is the case you can go to www.Garmin.com to use the webupdater
http://www8.garmin.com/support/download.jsp
Click on unit update. If that does not work then its most likely shot.
If you need further assistance please reply Thanks
If this works please dont forget to rate under my name on the premium post that you have.
Yes, this problem has been caused by the launch of a new satellite earlier this year. As soon as your unit gets a fix from the new satellite, it causes this problem. Simple immediate fix: disable WAAS in the setup. Permanent fix: go to Garmin website and update your unit's software and it will fix this temporary problem. Enjoy your GPS and don't forget to come back and tell us if this fixed your problem.
Screen is unreadable
I have garmin e-trex Legend and it was just working fine then the next time i turned it on the screen is unclear with lines thru all the writing. Please help.
Jun 04, 2008 | Garmin eTrex Legend GPS Receiver
Garmin GPSMAP 76CS GPS Receiver Logo
245 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
