Question about LG DR275 Recorder
How do you operate an LG DR275 DVD recorder without the remote control?
I have lost the remote controller for my LG DR275. The buttons on the front of my machine let me open and close the tray, start and stop re-play, and start and stop record. These buttons are just about all I need for basic operations, so I have no trouble re-playing all the disks that I have recorded since I purchased the machine. But there is no button on the front of the machine equivalent to the "enter" button on the remote control, so I can't instruct it to initialize a new disk to allow me to record on it.  Can anyone suggest a "workaround". Is there any other way to initialize a disk? What about "finalizing a disk after it has been recorded upon (although this requirement is not so critical, because I can still play an un-finalized disk on this machine).
I don't want to buy a replacement remote control just yet because I am sort of hoping that the original remote control will turn up (I suspect that my 3 yr. old grandson has put it somewhere).  Cheers, Tezza, Sydney Australia 14/10/08
  • 7 Answers
SOURCE: DVD locked in and door is not opened
For those users who just bought their machines, I would suggest warranty service. Roxanne2 should contact Philips directly with the seiral number, and they should be able to say which store they sold it to. That unit probably has a bad internal DVD writer drive.
The following solution should only be done if your machine is out of warranty unless you get permission from the manufacturer, as it will likely void the warranty otherwise:
Unplug the unit, disconnect all cables and move it to as static-free of an area as possible. Remove the cover, which usually means removing a lot of screws. Most DVD recorders have regular drives like you see in PCs. There is usually a tiny hole in the lower-right part of the drive that you can stick a small wire into, such as an unbent paper clip. You can then manually pull the drive open to get the DVD out.
Posted on Dec 08, 2007
  • 46 Answers
SOURCE: LG DR275 Initialize problem
hello..Carol..please refer to your user manual and look in the chapter that includes "how to" maybe you don't have to manually initialize the disks..this will be done automatically...keep it easy...please tell me how it went !...good luck...Ron
Posted on Mar 07, 2008
fieldy14
  • 456 Answers
SOURCE: lg dvd recorder dr275 initializing problems
replace dvd loader assy or mpeg pcb.
Posted on Jul 05, 2009
SOURCE: LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
Posted on Jul 24, 2010
SOURCE: LG RH274H DVD Recorder keeps opening and closing the disk tray
Did this problem get solved? I have the same machine and the same problem. Any help would be appreciated.
Posted on Aug 01, 2010
Cant play back recordings from my LG DR275 on any other device
I was asking the same question for the LG DR389 , but couldn't find any help . With time on hand I explored the remote control .
Try HOME , scroll down to a disk , go right and I got FINALISE ,
click and it activates . I can now play my DVD on any player or my PC . Good Luck !
Nov 21, 2012 | LG DR275 Recorder
Does somebody know how to make the LG RCT689H region free. It's a dvd Rewrittable, does someboady has expierience.
Access the DVD setup menu by turning on the unit without a DVD in the drive.
Press simultaneously the "arrow down" button on the right side of the DVD recorder and the "clear" button on the remote control simultaneously for about six seconds to access the options menu.
Use sideways arrow keys on remote control to navigate to OP6. Set value of option to "8F" (for region free) and press "enter" on remote control to save changes.
When message saying "save ok" appears press "menu/list" on remote control to exit options menu. The unit will reboot and is now able to play any DVD.
Mar 28, 2011 | LG BD550 Blu-Ray Player
Cannot view / record from AV input - no option on remote
look for a source button or 1 with a square with an arrow pointing in to it both are types of av button
Aug 25, 2009 | LG DR275 Recorder
Lg dvd recorder dr275 initializing problems
Jul 01, 2009 | LG DR275 Recorder
Problem with LG DR275 Recorder
lens needs cleaning or replacing
May 09, 2009 | LG DR275 Recorder
I need the manual of dvd recorder model dr275
You can find the manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/LG/DR275-_D
Click on the download link on the right side, then enter the 4 numbers so you can download the manual.
If you appreciate the time I took to help with this, please take the time to rate my response.
Hope this helps,
Chris
Jan 02, 2009 | LG DR275 Recorder
Trying to make my lg dr275 dvd player multi region...have tried the suggestions on website but none work
On the suggestions that you have on the website, tell us to use a CD-R wich I did. But after wasting a few of it, I tried with a DVD-R and worked much better.
Thank you very much.
Sep 25, 2008 | LG DR275 Recorder
May 29, 2008 | LG DE9523P DVD Player
Recording problem with LG DR275
Make sure your machine is well ventilated, mine had an overheating problem.
Apr 26, 2008 | LG DR275 Recorder
LG DR275 Recorder Logo
480 people viewed this question
Computer Repairing
Computer Repairing
