Question about Toshiba e750 Pocket PC
Align screen when systems starts up and get to the "align screen", there is no response when tap with stylus. Cannot get past this screen. Any help?
Tap push little longer time and release
Posted on Apr 29, 2009
Screen not aligned
Ref. HP ipaq hx4700: "Align screen" after hard reset or battery loss. I know others have had trouble getting past the "align screen" setup; I saw a suggestion somewhere that said the points were registered incorrectly (maybe in some, but not all of this model?); and they had to tap at locations other than the center of the cross symbol. I tried a variety of combinations, and found that if I tap ABOVE the center (but still on the vertical centerline) for the middle, top left and top right locations; and tap BELOW the center (but still on the vertical centerline) for the bottom left and bottom right...it worked. That brought me to the "Stylus" setup screen...which I also became "stuck" on. So far, I haven't found a solution to THAT issue yet. Gee, why can't they make these things simpler?
Feb 13, 2012 | Computers & Internet
Align screen problem
Sep 21, 2011 | HP iPAQ HX4700 Pocket PC
Touchscreen not reacting to stylus but the buttons work ok
  1. urn on your HP iPAQ Pocket PC.
  2. Use your stylus to tap on the "Start" menu.
  3. Tap on the "System" tab.
  4. Tap the "Screen" icon.
  5. Tap the "Align Screen" button.
  6. Tap the center of the cross-hair object carefully at each location as it moves around the screen.
  7. Tap "OK" to complete the screen alignment.
Mar 28, 2010 | HP iPAQ rx5915
Pocket PC 2003 Pro unable to align screen
the touch screen plug on the motherboard is disconnected
Sep 06, 2009 | HP Computers & Internet
Hx2415 stuck on align screen
i think you have a problem with you touch screen digitizer. you can send your device to a repair center to replace the TP only, without the need od replacing the entire LCM display panel.
A touch panel withou the lCD should cost much less than an LCD.
Jul 30, 2009 | HP iPAQ HX2490 Pocket PC
I have a tmobile wing the phone works fine but the touch screen does not work. i got the phone from someone and when i switch the sim cards it went to the screen that says to taap it to align the screen..i...
All you have to do is tap the screen with the stylus (slim pen that is position on the bottom right side of phone) where ever you see ( + ). Follow the plus sign ( + ) where ever it is on your screen. It should go in 5 different directions on the screen before it prompts you to the next screen. This process is mostly needed for hard reset (starting from original factory settings) or if you need to align the screen with the stylus.
Please make sure while performing the aligning task to tap the center of the (+) as possible. Not doing so may result in a poor functioning screen.
Mar 02, 2009 | T-Mobile Wing™ Smartphone
Samsung sch-i730 touchscreen problem
use buttons to go to start,settings,system,screen then click align screen
Jan 17, 2009 | Samsung SCH-i730 Pocket PC
GETTING STARTED
To align the screen tap frimly with the stylus on the X that comes on the screen..it will keep moving its position..do it precisely each time..the screen should get aligned in a short while..hope it helps!regards..
Nov 25, 2008 | HTC Touch P3450 Smartphone
Imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Oct 06, 2008 | i-mate PDA2k Pocket PC
Align screen
settings>screen>align screen
99% solved.
Aug 26, 2008 | O2 XDA Mini S Smartphone
Toshiba e750 Pocket PC Logo
160 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
