Question about Microwave Ovens
Kenwood Microwave 564.8568511 Light Replacement
I am unsure of how to replace the light for a Kenwood Microwave model 564.8568511. I removed the bottom cover containing the filters and it appeared nothing else needed to come undone for the microwave to slide out. I am trying to fix for my parents who have horrible eyesight.
  • Microwave Ovens Master
  • 9,098 Answers
Ifthere's no obvious removable cover over the bulb (and the owner'smanual doesn't address it) some disassembly may be required.
You can usually find Kenmore exploded views and order parts by entering your model number (564.856511) at the Sears parts site.
Always unplug a microwave before removing or installing any bulbs.
Ifit's an over the range type, remove the vent grille across the top andsee if bulbs can be accessed there. There may be a panel on the bottomcovering the light(s), instead.
If not, chances areyou'll have to remove it from the wall, then remove the outer cover. Ifso, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph besides the link to the Sears site.
Thescrews you need to remove should be pretty obvious, but a specialdriver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
SilverCrest Microwave SMW 800 A1 Bulb replacement instructions please
You have to remove the outer cover but be aware that after removal you are exposing yourself to potentially lethal voltages even with power removed. Remove the old lamp and install the new lamp you have kept on hand for this occasion. Reinstall the cover but test operation before reinstalling all hardware in case the replacement lamp does not work.
Aug 16, 2016 | In Microwave Ovens
How do I change the lamp in my Kenwood Simplicity microwave?
The lamp is accessed by removing the outer cover of the microwave oven. Hazardous voltages are exposed by removing the cover. Remove the lamp and install the replacement.
Feb 15, 2015 | Kenwood Microwave Ovens
Over the range Danby Model dom16a1wdb surface light replacement
a screw at the back side when removed get access to the bulb.Usually 40Watts bulb with1/2 " threaded
Mar 28, 2014 | GE JVM1790SK Convection/Microwave Oven
Replacement light we need a new light on the
The bulb is a special bulb, take the model and serial #s to your appliance parts store and they can get the correct replacement.
Mar 04, 2011 | Kenmore Microwave Ovens
I need 3 light bulbs for this model
You did not indicate the brand and model number of your microwave.
Many use a regular 40 Watt oven bulb as a replacement.
Simplest is to remove one light bulb and take it to a retail outlet that has a lighting department and make sure your purchase the same type to replace all three.
Jan 31, 2011 | Microwave Ovens
How to change the light bulp inside the oven?
Bulb replacement is not straight forward on this model, it requires the oven to be removed & stripped to gain access to the interior lamp... I recommend replacement by a Siemens engineer.
Mar 02, 2010 | Siemens HB77L25GB 900 Watts Convection /...
Handle broke off,ordered replacement unsure how to install
The door handle can easily be replaced on most microwave ovens by simply removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER.
If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Jan 29, 2010 | GE Advantium 120 Convection/Microwave Oven
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
238 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
