Question about Pioneer PD-F606 25-Disc CD Changer
Pioneer PD F606 25 cd changer door problem
Someone unplugged the player when a cd was playing and the cd got stuck. The doors wouldn't open because of the stuck cd. Someone went a little too far trying to get it to open and the bottom door popped off, along with this V shaped spring (a V shape with a circle inside between the narrow part of the V, the circle being the spring and the V being some type of leverage). Can't figure out how this spring fits, all the combos we tried leaves the door flopped open (the hinge is on the bottom). We know where the spring comes from, the circle part hooks on to the hinge entension but can't figure out how it goes beyond that. Any help would be appreciated, thanks, Dori
  • 28 Answers
SOURCE: my Pd-f4o7 25 CD changer
Mechanical fault, monitor loading arm but most likely belts.
capital98
Posted on Dec 22, 2007
SOURCE: pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Posted on Feb 20, 2008
  • 13 Answers
SOURCE: Pioneer PD-F505 lower CD door closer spring has sprung LOOSE!
use krazy glue to get the arm glued with the cd port or use electrical tape.
Posted on Jul 14, 2009
gwcoan
  • 49 Answers
SOURCE: my Pioneer PD - F606 25 disc player will load a
In any CD player/changer, this issue is often the result of either the CD itself or the laser optic being in need of cleaning. You can actually clean the CD by using your hands or a soft lint-free cloth and wash in dish soap and slightly warm water, then rinse. If the optic itself needs the cleaning, you can buy a kit at any stereo shop or Radio Shack. I would start with the CD and then clean the optic if necessary.
Posted on Oct 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: Where can i find an
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=Pioneer+PD-F606&uuid=A13098020997241
Posted on Jul 04, 2011
My Pioneer PD-M403 will not play computer made CDs. Why won't they play?
incompatibility is the cause of the problem. There is nothing wrong with both your player and the computer made CD's, they are not just clicking with each other.
The Pioneer PD-M403 player is also an old model, this could cause the problem.
There is not settings whatsoever that you can use ti solve this problem.
Take care.
Sep 25, 2010 | Pioneer PD-M403 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
Many Magnavox, Denon, JVC,
BMW 740 OEM and others.
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Jul 14, 2009 | Pioneer PD-F507 25-Disc CD Changer
My pioneer 100 disc cd changer (Pdf906) door gets stuck when opening and closing. I haven't used it in awhile kinda sounds like it struggles half way through of both opening and closing the front part.
my pd f100 disc pioneer is blinking and the first 25 disc compartment was sticking...i opened and found the main loading system was in the way of the 25 disc compartment...the compartment was rubbing on the loading system...i am trying to back up my loading system without breaking to re start the process and stop blinking...if anyone can help let me know...marc---- yours is probably starting to rub....also,the sping under the compartment needs crazy glue so it doesn't shift....that is another sticking factor i found on mine also.the spring wants to move underneath... open your panel and make sure not to touch any circuit boards...some of them --you have to be grounded or you'll fry it....
Mar 05, 2009 | Pioneer PD-F906 100-Disc CD Changer
My Pd-f4o7 25 CD changer
capital98
Dec 19, 2007 | Pioneer PD-F407 25-Disc CD Changer
Pioneer pd-m406 cd changer magazine style
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Sep 16, 2007 | Pioneer PD-M406 6-Disc CD Changer
U1 FAULT CODE
I had this same problem today.
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Feb 18, 2007 | Pioneer PD-F1009 301-Disc CD Changer
Car Audio & Video Logo
256 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
