Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Wiring harness 1974 sportster???
Bought a new coil and completly removed the old harness and installed a new coil and still no fire to the plug??? need help
    Scholar:
  • 29 Answers
I am assuming your bike is stock, or close to it. In 1974, all h-d's used a battery coil ignition with wasted spark. Battery positive flows from the ignition switch to the coil, through the coil primary winding to the points, then open or shorted to negative (through the chassis) depending on the points being open or closed. When the engine is turning over, this is what happens: The small cam that operates the points has the points in the closed position, so battery current is flowing through the coil primary, through the closed points to negative. This causes the primary winding inside the coil to set up a magnetic field. When the cam starts to open the points, the current tries to bridge the gap. If we let this happen, the big arc between the point surfaces would burn up in a hurry, and the plugs would not fire for the following reason: The ignition coil is a transformer. It has a primary and secondary winding.The secondary winding has many more turns of wire than the primary. When the secondary winding "cuts" magnetic lines of force a larger voltage is induced in the secondary. In the case on your sporty, we are boosting 12 volts to over 10,000 volts. This depends on 2 things: The number of lines of force and the speed they are cut. So, when the points just start to open, the condenser absorbes the current until the points are open enough to prevent arcing. Then the current flow through the primary winding stops. The magnetic field quickly collapses, cutting through the secondary windings that are connected to the spark plugs. The resulting high voltage (pressure) Jumps the gap on both plugs and lights the fire. One of the cylinders is on the exhaust stroke so that spark is wasted. So: ignition on : 12v at coil positive. With points closed, 0 volts at coil negative. If you read voltage here, the points are dirty or open or the wire from the coil to the points is open. Points open: 12 volts at coil negative. To check for spark, you don't have to crank the engine. Just manually opening the points should fire the plugs. After you get the plugs firing, post again and I will tell you how to razor tune this thing. It should start instantly with a perfect idle. Hope this is clear.
Posted on Jan 01, 2009
#10 plug black as if ive not done anything i bought a injecter new coils wiring harness plugs and wires
A black plug suggests a rich condition. If you remove the plug wire and hold it to ground and it sparks,you may want to consider a compression test on that cylinder given what you have already replaced. If the compression is low/none the plug won't fire and will get black
Nov 15, 2015 | Cars & Trucks
The #1 plug is not firing. It does not seem to be getting fire, if I move the plug to a different cylinder it fires. Any plug I install in the #1 cylinder does not fire.
Most likely the coil for that cylinder is bad. Unfortunately, you can't just replace a single coil - the entire coil pack is a sealed unit.
Jul 02, 2015 | 2010 Chevrolet Chevrolet Aveo LT
24 HP BRIGS V TWIN only 1 cylinder is firing what else can I check
No engine numbers to work with so here something to check. Briggs V-twins has set blocking diodes in the kill wire set. If one is shorted or leaky it will cause one coil to be dead if not both.
I just went this very same thing here a few weeks ago. In my case I started out one dead coil for sure installed new coil and still had no fire. Remove the kill wire as I normally do during testing in case a short and the new coil fired fine. Easier to just replace the wire harness then repair it. Out of curiosity I checked out the wiring harness and found one diode shorted and other one leaky.
Jun 01, 2015 | Garden
1974 1000 sporty, front cyl doesn't fire
Did you check the Ignition, Points and Condenser. Also check compression there may be a stuck valve.
Jun 18, 2014 | 1979 Harley Davidson XLH 1000 Sportster
I need a wiring diagram for a 1974 Yamaha DT100a
Hi, Rick for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1974 Yamaha DT100a wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha DT100A 1974 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-dt
Jun 18, 2012 | Yamaha DT 360 Motorcycles
Kawasaki zx6r wont fire
I'm doing the same thing with a 09 zx6r motor and ran into the same problem came to find out the factory ignition switch has a 100 ohm resistor built in on the hot in wire for anti theft
May 16, 2012 | 2007 kawasaki ZX-6R
I have a 1984 harley sportster with a 3 wire sensor(white,black,and blue wires) that i need to hook up to my new dual fire ignition coil, and new barrel type key ignition. not sure where the wires for...
I can send you a complete wiring diagram for your Sportster. The wires you are talking about go to the stock igniton unit, the "brain box" or "black box" that is behind the triangular plate on the right side of the bike as best as I can remember (1984 was a long time ago). There should be two white wires on the coil and one is the "hot" wire and the other goes to the ignition unit. The pink wire goes to the tachometer. The blue wire goes to the opposite side of the coil from the white wire, same side as the pink wire. The black wire is a ground wire for the igntion unit most likely. But, I'm confused by you saying the wires go to a "sensor". The only sensor on the bike is in the timer cavity on the right side of the engine and the wires coming from it are different color from what you mention. Are you sure it's not simply a plug? Contact me directly at wd4ity@bellsouth.net and I'll send you the diagram. Remind me of what you need.
Steve
Jul 25, 2011 | Harley Davidson XLS 1000 Motorcycles
Squirel ate through wire harness connector on coil pack. I have found new connector with generic black 4 wire harness, but need to know the correct order to connect to old (multi-colored) wires leading...
Check the right wiring diagram connections... 2002 Mercury Cougar 2.0 liter DOHC L4 VIN "3"
Also, I find few diagrams about Igniotn System...
Fig. Engine Ignition, Page 01 (2002, System overview)
Fig. Engine Ignition, Page 02 (2002, Duratec-VE)
Fig. Engine Ignition, Page 03 (2002, ZETEC-VCT)
Hope helps.
Feb 22, 2011 | 2002 Mercury Cougar
Replace coil on Harley Sportster 883R 2006/7
Replacing a coil is one of the simpliest jobs on a Harley. You've only got four connections. Two of them are spark plug wires and it makes no difference which wire goes to which cylinder as the Harley ignition system is a "dual fire" type system. Both spark plugs fire at the same time every time a piston comes to top dead center.
On the other two connects, the small primary connections, these make no difference either as the coil in a non-polarized type coil.
So, nothing to it, just make sure you are using the correct coil for the bike. The primary resistance of the coil should be about 3-4 ohms for your electronic ignition system. Simply unbolt the old coil and bolt in the new one.
Jan 17, 2010 | 2000 Harley Davidson XL Sportster 883
Rear cylinder not firing
The first thing I would do is replace the spark plugs again. You can foul a plug and it will cause you more problems than you can ever imagine. I see you have done all the logical things that I would recommend but I did not see you have replaced the plugs after the 200 miles. You would be surprised at how many times a $2.00 part can cause fits beyond belief.
Dec 07, 2008 | 2000 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
506 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
