Question about Javelin Systems Inc Javelin LC PC Desktop
Using windows 98 shut down problem
Shut down problem when windows 98 is loaded.
how do i solve this problem.....help
  • gaudencio Oct 15, 2008
    i got joo's message but i install the win98 in c:\win98 drive. i cannot direct it to go to c:\ drive instead of cdrom. i don't have cdrom for javelin lc.
    i don't have a cdrom drive for javelin lc, i install win98 in c:\drive.
    how do i direct the fix solution to c:\win98
  • Javelin Syst... Master
  • 4,338 Answers
There is a Win98 shutdown patch from Microsoft. But Microsoft stopped supporting Win98.
You can find the patch on this website:
http://freepctech.com/pc/002/files007.shtml
It is the 3rd item listed.
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 14, 2008
  • JDTec
    JDTec Oct 15, 2008
    All you have to do is download it to your desktop and double click on it to install the patch. It is a good file, I just downloaded onto my PC. I did not run it because I have XP Pro.
    What is "javelin lc"?
    Joe
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
Driver problem for colorpage-vivid 3150 scanner in windows xp
you can get the driver from
http://drivers-free-download.com/driver-genius-colorpage-vivid-3x-scanner-driver-windows-98-me-2000-xp/
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Mar 26, 2010 | Genius ColorPage Vivid Pro II Flatbed...
Windows 98 will not shut down
There are several reasons that can cause old Windows operating systems to shut down. Has this always been an issue or did it just start happening? If it just started, then think back to what you may have changed on the system...hardware or software. Remove software or hardware and try it again.
You can also try disabling the fast shut down sequence by following these steps:
1. Go into msconfig (this can be done by typing msconfig under the command prompt)
2. Go into advanced.
3. Put a check mark in the disable fast shutdown box.
4. Click ok and ok again.
Try shutting it down.
If that doesn't do the trick or its already disabled then check out this link:
http://support.microsoft.com/kb/202633/en-us
I hope that helps. Check back and let me know! Thanks.
Apr 11, 2009 | Microsoft Windows 98 for PC
Pendrive Problem in windows 98
you have to use xp os.because windows 98 is tatally back dated. thats why its not opening. or you can check it into another xp os. computer if it is open then your sure that windows 98 is not supporting, or if it is not open then your pendrive has some problem.
Mar 17, 2009 | Microsoft Windows 98 for PC
Windows 98 SE Driver for Transcend Jet Flash V60 8GB #TS8GJFV60
hi, i srinivas, i am using dual booting of win 98 & windows xp operating systems. when i am using my transcend pendrive in win xp which is easily working, but in win 98, how can we install perpect drivers for my transcend pendrive.
so please give the solution to solve my problem.
Jul 13, 2008 | Electronics - Others
Reloading windows 98 on a Panasonic Toughbook CF37
http://support.microsoft.com/kb/262381/en-us
Restart in Safe Mode and Use Msconfig.exe loadTOCNode(2, 'resolution'); Restart your computer, press and hold down the CTRL key after your computer completes the Power On Self Test (POST), and then choose Safe Mode from the Startup menu. For additional information about Windows 98 startup, click the article number below to view the article in the Microsoft Knowledge Base: 178548 (http://support.microsoft.com/kb/178548/EN-US/) No 'Starting Windows 98' Message at Startup After your computer restarts in Safe mode, use the System Configuration Utility tool (Msconfig.exe) to minimize conflicts that may prevent your computer from finishing Setup.
To start and use the System Information tool: 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Information. 2. On the Tools menu, click System Configuration Utility. 3. On the General tab, click Selective Startup, and then click to clear the following check boxes: • Process Config.sys FileProcess Autoexec.bat FileProcess Winstart.bat File (if available) • Process System.ini FileProcess Win.ini FileLoad Startup Group Items
Dec 05, 2007 | Computers & Internet
Errors and problems I NEED HELP!!!
1)Format your Drive. 2)Download a new copy of Windows 98 from Any Warez Site. 3)Make sure your Cmos Settings are at best performance.
Oct 09, 2007 | Microsoft Windows 98 for PC
Dvd cd-rom
Which OS you are used.if You used windows 98 then boot up your pc with bootable windows 98 cd,it loads cd rom driver automatically.
Oct 07, 2007 | LG CRN 8245B (CRN-8245B) Internal 24x...
Does not shut off
Hi here are so links that may help you troubleshoot your shutdown issues... www.dove.co.nz/support/win98se-fix1.html support.microsoft.com/kb/238096 209.167.114.38/support/techsupport/tsbs/all/-TSB000739.htm This used to be a nightmare problem.. waaayyyy back..
Aug 14, 2007 | Panasonic Toughbook CF-27 Notebook
Javelin Systems Inc Javelin LC PC Desktop Logo
256 people viewed this question
Top Javelin Systems Inc Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Rick Moore
Rick Moore
Donald Pera Deane
Donald Pera Deane
Are you a Javelin Systems Inc Computer and Internet Expert? Answer questions, earn points and help others
