Question about Dell Latitude C810 Notebook
Dell laptop Latitude c 810 BIOS revision A12
As soon as computer is turned on the following words displays:" An unsupported memory modules was detected. A bad or unsupported memory module was detected. Please remove the unsupported memory module in socket 1, nearest the center of the machine. Strike the F1 key to shut down." Please tell me how to fix this problem... Thanks, Ricky Cooper
  • rckycooper Oct 14, 2008
    That was very helpful. The computer is now working great.. Thanks for your help...
  • compgeek09 May 11, 2010
    Have you recently changed or upgraded the memory in the laptop? It sounds like the ram is the wrong kind?
    Problem Solver:
  • 12 Answers
You got the wrong type of memory installed open the memory bay and remove move it from socket 1
Posted on Oct 14, 2008
  • richard reyes Oct 14, 2008
    your very welcome if possible could you please rate me thanks have a good day
  • Dell Master
  • 4,338 Answers
Your laptop's memory is malfunctioning. To remove the memory, power down your laptop.
Turn it over and you should see a cover about the middle of the back. Open it and there you should see the memory. You may or may not have more than 1 memory Dimm. Also there are 2 slots. The bad memory is the one in the first slot. Take it out and put the other in it's place. the laptop should boot up ok, but slower because of the missing memory which you should replace.
If you get the same message, replace the memory with the one you took out, then reboot.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
  • JDTec
    JDTec Oct 14, 2008
    Glad to help.
    P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved.
    • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
    • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
    • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
    • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Need to unlock my Dell Latitude XT2 #850NLL1-1F5A BIOS password. Please help I can't get into my laptop after upgrading my bios from Bios Rev. A12 to A15
Anonymous,
You will need to contact Dell by phone in order for them to reset your bios password. They will verify ownership and then provide information for resetting the password.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jun 05, 2015 | Dell Computers & Internet
Unlock of Bios on Dell latitude E5500?
Remove your cmos battery for a while then setup bios again before booting operating system.
Feb 23, 2012 | Dell Latitude E5500 Laptop
Remove or reset dell latitude c640 bios password
How to reset The Latitude C640 Bios password?!
1.First flip your laptop over and remove the battery, as well as any cables connected to the laptop.
2.Remove the screw latched into the memory panel on the bottom of the computer found near the rear.
3.Lift the panel off and expose the memory modules.
4.Seek for a small push-button and press it, holding it for about two seconds. Reassemble your laptop and start it up.
Thank You!
Feb 01, 2011 | Dell LATITUDE C640, P4...
My computer is saying a bad or unsupported memory module was dettected pleas remove the unsuported memory module in socket 1 nearest the mini pci slot on a pp01l computer what do i do
remove the memory, turn the laptop over and unscrew the square looking plate on the botton. remove that memory module.
if its empty then most likely its the on board memory that is suspect and you will need to replace the motherboard (extended insurance?)
always double check specifications and speeds two or three times before ordering extra ram. just because it fits doesnt mean it works.
Jun 10, 2010 | Dell Latitude C640 Notebook
An unsupported memory module was detected a
Sounds like the Memory Ram that you tried to install went haywire. Take it out and make sure this ram is compatible.
Apr 10, 2010 | Dell Latitude C810 Notebook
BIOS PASSWORD UNLOCK OR FALASHER BIOS "DELL LATITUDE D620" (revision A07)
if you do not have the bios password you have to open it ..and clear bios by short the pins if you find them...or remove the bios battery for 10 seconds..and will be on factory optimal defolts
Mar 27, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a Latitude D630 laptop and I recently purchased a docking station to use with it. I tried my laptop's PA12 Power adapter When I initially connected everything and placed the laptop on the dock an...
Try updating to BIOS to version A16 from http://support.dell.com Ensure you are not attached to the docking station when flashing the BIOS. Once updated, connect the 90W adapter to the docking station, connect your laptop to the dock, and power on using the docking station power button.
Nov 13, 2009 | Dell Docking Station for Latitude D600
Dell C600
Here goes, first download the A12 BIOS from this page or others,
http://drivers.softpedia.com/get/BIOS/Dell/index5.shtml
Then, Run this file to make a bootable bios floppy disk. Reboot the laptop floppy will start dos mode, the updater will detect any bios newer then A12 and say finished without changing anything and come to an a: prompt.
type dir for a list of files on the floppy. If your typing gets you wierd symbols try holding the Fn key (lower left) lookfor the filename C600_A12.exe or somthing like this. type it at the a prompt exact. The bios flash will check system bios and ask your permission to revert back to A12. say Y.
Computer will reboot. take floppy out.
My batteries charge grat now, but I don't get all ythe settings pages in Bios that I should, It seems to hang when i enter Bios. Laptop works fine though. i have installed and tries all bios from A12 yo A23, the A12 seems to be the best. No problems from winXP.
Oct 01, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
1600sc second CPU
Hi
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows - http://ftp.us.dell.com/bios/PE1600SC-BIOS-WIN-A12.exe
PowerEdge 1600SC, BIOS A12 Floppy Update Package - http://ftp.us.dell.com/bios/PE1600SC-BIOSA12.exe
Mike
May 14, 2008 | Dell PowerEdge 1600SC Server
Black screen say unsupported memory , remove the unsupported memory from socket 1
I think you might have a faulty memory module. The socket where you push the PC card is not the Socket 1. I think the notebook is complaining about the Memory socket witch you can access if you remove the memory cover(click for details) on the bottom of the notebook. Try reseating the memory module, remove it from the socket and install back. Make sure the memory contacts are clean and not oxidized; clean them with an eraser if they oxidized. Try moving memory from one socket to another. If you have two memory modules installed, remove them one by one and test the notebook with only one module installed. Find out which module is bad.
Oct 19, 2007 | Dell Latitude C610 Notebook
Dell Latitude C810 Notebook Logo
558 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
