Question about Kyocera Office Equipment & Supplies
Fs-1030d even when set tray1 as source will print from mp feeder if paper in it
Printer continually states "mp tray is empty" WHEN IT IS NOT
Posted on Aug 11, 2011
    Problem Solver:
  • 11 Answers
If paper in mp tray it can print mp tray only,
There is no option to chane the settings.
Posted on Oct 14, 2008
Kyocera fs -1030d printer show message removal original from document processor
These are notarius for having a cabling problem.the cable that runs from the d/f to the main unit go bad. It's a process to change one I would seek help by a person that has done it. Could be the flag or accuator that the paper hits. Or just a sep roller can do a lot for a sick feeder.
Feb 11, 2017 | Kyocera Mita FS-1030D Laser Printer
Told that this is a PCL5 type printer and can be used as a plug n'play, and no need to install a driver. It does work, but will not hold the programming. I only want to use Tray1.
the thing is that with plug and play equipment, when you plug it into the pc and turn it on Usb connections) , there is a small message just above the task bar which says installing driver for printer
it is the way that the pc recognizes the printer in a port
it may be best it you go to the control panel ,printers and devices , add a printer and install it properly
Oct 13, 2016 | Lexmark Office Equipment & Supplies
Dear Madam/Sir Our FS-1030D printer makes an
It is a Paper stepping Problem (common on kyoceras), you can try cleaning rollers with some alcohol, if problem insists you should take it for repair.
Aug 24, 2013 | Kyocera Mita FS-1030D Laser Printer
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
What does it mean by Load MP feeder letter?
That means whatever you are trying to print is set to feed from the MP tray or Multipurpose Tray. The tray that folds out that is used to feed thicker paper or envelopes in. Just check your print setup screen and tell it to feed from the lower tray or tray1. If that is what you were trying to do.
Dec 28, 2009 | Dell M5200n Laser Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
IBM infoprint 1422 won't feed through paper tray, only works with mp loader
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
Oct 22, 2008 | IBM Infoprint 1422 Laser Printer
Wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Oct 11, 2008 | Kyocera FS-1030D Laser Printer
375 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
