Question about Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive
DVD Rom opens up automatically.
Hi all,
i have got my smasung DVD rom.it opens up and closes automaticallywhenever i try to open my computer and some other drives this problem occurs
  • mavron Oct 18, 2008
    Thanks for ur response ...but the problem still exists.
    when i try to update the drivers of my rom it said ur drivers are up to date. i tried this with my driver cd of DVD rom.
    whenever i open up mycomputer and when i double click on ne of the drives new window opens up and DVD rom also opens and closes. i have chkd the settings for it,its proper for open each window in the same window.
    looking for the response
    thanks
  • vinay_cool88 Nov 26, 2008
    my combo doesnt gets open even after pushing button several times
    then it suddenly comes out and automatilcally closes
    Master:
  • 538 Answers
You may wish to re install the drivers for this unit and see if it continues to happen
Posted on Oct 14, 2008
Computer does not see cd wp system
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Nov 23, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My dri8ve will not open and close with the push of the button.
Hi. if you are using a cd rom that dosnt open and close. try the following. unplug your HDD cable to the hard drive. just use cd rom. if cd rom open. you must use a separate cable. if problem continues then you must take cd rom to the nearest Computer electrical expert to fix.
good luck
Nov 11, 2010 | Computers & Internet
Dvd drive won't open
you can try opening it with paperclip if it's stuck. Straighten the clip and locate a small pinhole on the drive it and insert the clip in. You might need to push the paperclip in an out a few times to eject the drawer.
Jun 19, 2010 | Computers & Internet
Dvd rom drive does not work
Try to open control panel then click add hardware. If you have entered the dialogue box, answer whatever is asked according to what you're searching. Then click whatever hardware your PC would like to detect then click finshed. After the detection, close the wizard box then try to open your DVD ROM and try it.
Hope this answers your question.
Feb 18, 2010 | Artec 16X DVD-ROM 48X CD-ROM Drive with...
Dvd rom will not stop oening anc closing
Check its open/close button if it stick. It should have an ample play.
Apr 03, 2009 | HP LightScribe dvd640i (DVD640I)...
Computer won't recognize new GSA-H55L Super Multi DVD Rewriter. I have it set to slave, all other settings seem to be okay.
hi,
try this...
> click on start--> run
> type in devmgmt.msc
> expand dvd or cd rom drives
> check whether your dvd rom is listed
> if so right click on that and select properties.
> check whether it is enabled or not.
> if that is ok, close everything
> open control panel--> add/remove hardware
> search for your dvd rom
let me know what is the result
thanks and regards
agnel
Mar 17, 2008 | Computers & Internet
Cd-rom/dvd-rom door won't open
Hi!This is not a big problem...All you have do is take a pin, needle or something and just insert it into the small hole near your cd-rom drive..try this repeatedly while pressing the eject button..If it doesn't work you will have to unscrew the two screws on the right of your keyboard..doing this will give you the access to the cd tray and you can remove the cd and put it back together..
Nov 13, 2007 | Averatec 3200 Notebook
The dvd rom does not open. takes a long time to actually turn on and after is on the dvd rom doesn't open. is there a solution?
it doesn't reconized the dvd-rom, but to open it, unplug it for 30-45 seconds. plug it back into the power strip/wall. At that same moment tap (2/3 times) the stop/eject button . do not press play (it will try to load automatically) . try it once more (if it do not open, this time a full minute) presto it should open.
Nov 02, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive Logo
118 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
