Backlight inverter Sir what is a backlight inverter? because you said I need to replace it,what is it look like it is an IC
  • neiljopia Oct 20, 2008
    thank you very much sir.Sir if i plug my CRT monitor compaq mv520 into AC outlet and I turn it ON the power led flashing orange to green color and vice versa and I turn it OFF back then I connect into The system Unit and I turn ON the Systen Unit as well as the monitor and I found out that the power led stop flashing but from green turn into orange which is stand By Mode.Sir My System Unit have no problem because I try it into other monitor it works fine So the problem is in my monitor.Sir it is posible that the problem is in the Power Supply of the monitor? Help me Find out sir,Thanks in advance!!!
  • 3 Answers
A backlight inverter is the power supply to power the lamp or lamps in an LCD display, so when you look through the LCD there is a souce of light behind it. Kind of like holding a peice of paper up to a light and looking through it, The light from behind shines through the paper or in your case the LCD display. You would have to open up the LCD case in order to find what is usually a long thin board, similar to the one below. This may need to be replaced or you may get lucking and just be able to replace the F1 (fuse) component and fix it. (or have a techical friend do it for you)
Posted on Oct 19, 2008
  • DICKHUX Oct 19, 2008
    Example Inverter Board
My tv started to hum have figured it to be part of the backlight NEED HELP?
Hello Sir, Hi, if that is the case, your inverter board is generating audible high frequency noise. the inverter board is true to produce high frequency pulse needed by the LCD, but if should not be audible. try replacing the inverter board and see if the noise will dissapper .
Jul 17, 2012 | Insignia NS-LDVD26Q-10A 26 in. HD-Ready...
20/02/11 Dear Sir/Madam. I got my Dell Inspiron B130 from a relative almost three years ago. Last week I turned on the laptop but noticed only a quick flash on the monitor then it was completely...
you can not buy a back light on its own you would have to buy a screen or an inverter its best to take it to a computer shop where they will test the screen and inverter and say what is faulty
Feb 20, 2011 | Computers & Internet
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
I have 140 LG 32LC7DC LCD TV's. 14 out of 140 failed. They would not power up. Have you heard of this problem with this model of LG?
Power Supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC7DC 32 in. LCD HDTV
Replacement Backlight inverter
ebay may be a good place to look?
Dec 09, 2009 | Intel CTL E09L 2goPC Laptop
Screen is to dark. cannot see letters very well.
Suggest you press the Fn key And the key to increase brightness, first. (Should be a key that has a sun icon on it)
Barring this does not increase the visibility of your LCD screen, the I suggest the Backlight is bad, or the Inverter.
The Backlight is a type of CCFL tube (Cold Cathode Fluorescent Lamp) mounted to the LCD screen. The LCD screen needs the light given off of the Backlight.
Replacing the Backlight is a daunting task, and if done wrong, will cause possible damage to the LCD screen.
The LCD screen itself has a thin metal frame holding the components of the LCD screen together. This frame must usually be opened on the side that has the backlight, to access the backlight. The components that make up an LCD screen are fragile, and can easily be damaged.
The Inverter supplies power to the LCD screen, as well as the Backlight.
Inverters do go bad, but commonly it's the Backlight to go first.
This shows a typical Backlight replacement. It IS not an advertisement to attempt this yourself, but a reference tool for information.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Nov 16, 2009 | Itronix GoBook III Notebook
D600 Latitude laptop - LCD showing ghost/dim images
Connect an external monitor to your laptop and power it up, if you seethe normal Windows images then the video card and laptop is OK and theproblem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dimimage and/or dark display on the laptop's LCD screen indicates a faultyLCD backlight and it could be the inverter that supplies high voltageto the CCFL lamp or it is the CCLF lamp is nearly burnt out or burntout, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Thank you Sir, Have a nice day.
Sep 19, 2009 | Dell Latitude D600 Notebook
"Upgrade" of Backlight Panel
just replace what failed.
I replace the surface mount FETs on the inverters.
Dec 03, 2008 | Sony BRAVIA KDL-40V3000 Television
Computers & Internet Logo
822 people viewed this question
David Payne
David Payne
