Question about Leisure SPC-54 Patio Heater
Patio Heater problem
I purchase a All-Pro SPC_54 patio heater this summer. Used it once during the summer without any problem. I tried to turned it on this October, but would not work. The pilot would light, but when the control knob was release after 1 or 2 minutes, the pilot light would go out. When I opened up the assembly, the pilot light seemed weak and I also noticed a flame coming out from the pilot air inlet opening. The flame was blue and yellow, and it never seemed to get close to the sensor next to it. My wife and I really want to use it this fall....please help. Thanks
  • 41 Answers
SOURCE: Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Posted on Dec 22, 2007
  • 625 Answers
SOURCE: Kirkland heaters - outdoor patio
get a new thermocouple
Posted on May 27, 2008
SOURCE: hampton bay patio umbrella bent pole
I have a frame for a 9 foot rectangle Hampton Bay Umbrella but the Umbrella itself fell apart. Anyone know where to get just the umbrella?
Posted on Jun 12, 2008
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
  • 10865 Answers
SOURCE: Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
Posted on May 27, 2009
My gas endless summer heater shuts the flame off abruptly after 5 minutes or so. why??
The first consumable part to fail on a gas patio heater is the thermcouple, these can last anywhere between 1 year to 6 years. When faulty it will cause the heater to shut off when turned on at pilot. Found this site very useful patio heater problem solving.
Nov 18, 2011 | Endless Summer 233010 Natural Gas...
The lid on our Endless Summer Patio Heater 200209 is bent. Can it be fixed? If not, where can I purchase a replacement?
If you are referring to the heat deflector top on the upper most portion of the heater. yes, it can be repaired , if it is not to severely bent. It would require removing it from the heater to straighten it. If the metal is creased, it's not worth repairing.
Blue Rhino is the manufacturer for Endless Summer Patio Heaters, as well as several other brands. You can contact them for replacement parts @ 1.800.762.1142
Jul 06, 2011 | Endless Summer 200209 Open Flame Patio...
Need service repair rep to come to my house and repair endless summer heater
Sean, for that request, you'll have to contact the Dealer/Retailer you purchased the patio heater from.
May 02, 2011 | Endless Summer 200209 Open Flame Patio...
I have an endless summer patio heater the pilot lights but the does not stay on when you turn the knob to start the heater. Got it on once but then the flame blew out and could not start again
You need to replace the Thermocouple. Endless Summer Patio Heaters are manufactured by Uniflame, which is owned by Blue Rhino. You can order the Thermocouple direct ly from either company. Just make sure you have your Model Number handy.
Mar 06, 2011 | Endless Summer 2009 Open Flame Patio...
Replacement regulator required for Endless Summer patio heater
These regulators can usually be purchased from Canadian Tire or Home Depot. If you are unable to locate the exact replacement, email the model number located on the regulator and I will locate one for you. I am in the GTA and can be contacted via company website.
But one question, why do you think the regulator is defective? These rarely fail.
Nov 03, 2009 | Endless Summer ES92000 Patio Heater
Patio Heater 40,000 BTUs..lights no problem, but has yellow orange flame..i think it should be blue...does this mean a blockage? ALL PRO SPC 42PH by national-riverside
One of two things, you need to clean it but it may only that the tank at the end and soon need to be replaced ort refill… check and see if anyone played with the pressure regulator.
Please let me know how this worked for you and please do not forget to grade my assistance so I am able to continue to provide you with better service. I will be working with you to conclusion of the issues.
Sep 26, 2009 | Endless Summer 1501 Patio Heater
Patio Heater won't stay lit?
The first possibility is a bad regulator, easy and cheap to replace. The second possibility is a bad thermocouple, and the third possibility is a blockage in the pilot assembly. The last two problems require you to take the head apart to replace the thermocouple or clear the blockage. If you are not comfortable taking the head apart, hire someone to do it.
Jun 14, 2009 | Endless Summer gwt501a Open Flame Patio...
Need part # 56-01-127 pilot assembly
Call this # and order 1-800-762-1142. I hope this helps.
Dec 19, 2008 | Endless Summer 2009 Open Flame Patio...
Leisure SPC-54 Patio Heater Logo
88 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
