Question about Canon Office Equipment & Supplies
Fax interrupting incoming phone call - Canon Office Equipment & Supplies
    Genius:
  • 2,120 Answers
Adjust fax machine NUMBER OR RINGS to as high as possible or buy a fax / phone switch.
Posted on Oct 14, 2008
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
What is an error 283 on a hp officejet J6400
Definitions
  • A communication failure occurred between the two machines.
  • The user at the remote machine might have pressed the Stop key.
  • The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
  • The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Solutions
  • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
  • Set the host machine to receive at a slower transmission speed.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems
    Aug 31, 2011 | Office Equipment & Supplies
    What does com error 232 mean
    -A communication failure has occurred between the two machines.
    OR
    -The user at the remote machine might have pressed the Stop button.
    OR
    -The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Call waiting should not be used on a line with a fax machine.
    OR
    -The power at the remote machine has been interrupted or deliberately turned off, causing the fax session to be interrupted.
    Try this steps to resolved the issue:
    *disable Error Correction Mode (ECM)
    -press Setup>Advance Fax Setup>ECM-turn it off
    -Fax quality might be degraded.
    *Set the host machine to receive at a slower transmission speed.
    -press Setup>Advance Fax Setup>Fax Speed-change it to slow or medium
    Jun 29, 2010 | HP LaserJet 3330 All-In-One Printer
    Comm error 232
    This is the common cause and solution: A communication failure has occurred between the two machines. On the other hand, the user at the remote machine may have pressed the Stop button. Alternatively: the power at the remote machine has been interrupted, or deliberately turned off causing the fax session to be interrupted.
    Solution:
    1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
    2. If the error persists, and error correction is in use for the fax session, disable ECM . (See Error 222)
    Good luck
    Jun 12, 2010 | HP LaserJet 3050 All-In-One Printer
    Phone calls interrupted by fax tones
    if you are using the EPABX pls. check the technician regarding that programming.....
    Feb 17, 2010 | Samsung SCX 4521F All-In-One Laser Printer
    What is the meaning of eror 232*
    Error Code: 232
    Solutions
    • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM .
    • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems.
    Nov 04, 2009 | HP OfficeJet J4580 All-In-One Laser...
    Fax noise from all in one interrupts phone calls
    Setup all in one fax setting to more than one ring.
    Apr 01, 2009 | Office Equipment & Supplies
    FAX errors 345 346 and 350
    HP.com has a web page for your product with all of the fax error codes listed and how to interpret them:
    Fax Error Codes
    Once the page opens, you'll have to scroll down until you find your error codes in the list. The codes in that section of the page don't seem to line up well. All of the codes have to do with the quality of service on the phone line. If the people you're faxing to are receiving all of their faxes except from you, I'd suspect your phone line may have a problem. Here's what I got from the list:
    The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
    OR
    OR
    The remote user has pressed the Stop key while the reception was in progress.
    OR
    Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
    Check with your phone company to see if their are any problems on your line. It looks like anything that even momentarily interrupts your phone connection will cause these errors. Good luck.
    Nov 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    Pixma mx 310 fax auto
    enter rx settings and select teleline as fax priority.
    Mar 30, 2008 | Canon FAX-JX200
    Faxes always interrupted by incoming calls
    You might find an answer here:
    http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000300/000001/faq000301_020.html?reg=us&c=us&lang=en&prod=mfc5460cn_all
    Its quite difficult to give a qualified answer when so many different telephone companies and techniques are avaiable.
    Plz search the mentioned faq for further instructions.
    In case you cant find an answer, call brother hotline for free support ;-)
    Merry X-mas where ever you are!
    Dec 21, 2007 | Brother MFC-5460CN All-In-One InkJet...
    76 people viewed this question
    old marine
    old marine
