Your water valve inside the washer is either stuck, no water going to hose or the washing isn't sending voltage to open the valve. Start first by removing the hose. If water starts spraying all over the place turn off the hose and check for a blockage when it connects. Sediment may have clogged the screens there. More than likely a new water valve should take care of the problem. Sometimes sediment can pass through the screen and accumulate causing it not to open causing it to stick when voltage is applied as well.
