Question about Compaq (172612001) Motherboard
Monitor cannot recognise MoBo
I have inherited a HP Evo mini tower. The systems have been wiped clean, which is OK with me. When I tried to reboot to clean install, the moniter does not recognise the tower and remains balnk. I have haave tried to reset CMOS, have disconnected all drives to reduce conflict, yet i expected to see some indiocation that the CMOS has kicked in...nothing. Power is getting through to the MoBO, fans etc are working, LEDs are lighting up but that is a far as I am able to get.
I can go no further until I can get the monitor to work. I have tried three different monitors and the results for all three is the same.
any suggestions???
    Genius:
  • 1,605 Answers
Try a different video card. any type you can get your hands on, PCI is perferred.
Posted on Oct 14, 2008
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Hi I was trying to turn on the monitor but when i turn it on, it says welcome and goes black after showing the screen for 1 second. How do i fix this?? I have a Windows XP
make sure the cable conenting to the monitor of the computer and the tower is proerprly plug in ..Try to remve the cable clean both ends of the cable make sure its clean .Clean also the ports on the monitor and on the tower thentyr again .In case still nothing happens replaced the cable first but incase it hapens probably is on the MObo of your computer thanks
Hope it help
May 22, 2011 | Elo 1715L 17 inch LCD Monitor
Hello I have a Dell optiplex GX270, with the mobo it comes with. It will boot, has sound coming from the HD, CD drive, cpu cooling fan, etc, but will not show anything on the monitor and the keyboard...
Hi,try swapping the Memory chip ie putting it on the other slot,also test with another processor if after all these system does display,i'll suggest you go get a new board.
Jan 04, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
Hp tower will not reboot
Sorry to hear you're having problems.
As simple as it sounds - remove the cover and blow out the system.
I hear that Best Buy and Staples are giving free check ups. I would check with them for the freebee and not tell them it isn't booting. Just an idea - sneaky in a way but I have had pc's not boot and them after a cleaning boot right up.
This isn't a permanent fix you understand.
Best of it
Rice
Mar 28, 2010 | HP Compaq dx2300 Microtower - RT950UTABA...
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
Required network driver of d51s compaq system
I went to HP.com/Support, typed Compaq Evo D51s into the search bar, and it came up with the page, for the Compaq Evo 300s Convertible Mini-Tower.
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=96281&submit.y=8&submit.x=10&lang=en&cc=us&y=7&x=7
If this is indeed your computer model, and you have Windows XP Home Edition for your Operating System, here is the drivers download page, with the Network drivers,
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=97101&prodTypeId=12454&prodSeriesId=96281&swLang=13&taskId=135&swEnvOID=1098
Should you have a different Operating System, here is the page where you choose,
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=97101&lang=en&cc=us&prodTypeId=12454&prodSeriesId=96281&taskId=135
May 13, 2009 | HP Compaq EVO D51S Intel Desktop PC -...
My tower had a virus/trojan horse AND IT DOES NOT START OR REBOOT
You have loosing problem.
1. First of all check all the cable connection for loosing in your CPU.
2. Second re-insert your RAM after cleaning.
3. Check your power cable for loosing.
4. I am Hundred percent sure, your RAM is loose. Just unplug and replug your RAM after cleaning.
5. Hard Disk cable may be loose or SMPS cables are loose.
Try these steps. There is no hardware problem in your system.
Apr 27, 2009 | Computers & Internet
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
