Question about GE GSS20IEP Side by Side Refrigerator
Noise Recently can hear a "wind" noise coming from what seems to be the freezer side of the unit. Sounds like wind escaping thru a car window that is not completely closed. Noise goes up and down when compressor is running. Does not change when I open the door(s). Somewhat high pitched. Freezer side is not iced up, although ice crystals do form around the chute that dispenses the ice but not enough to interfere with operation.
  • Rosendo Madero
    Rosendo Madero May 11, 2010
    need more info what brand side by side or top mount ?
  • 120 Answers
Ok i had this same problem last week with one of my customers i check voltage at the evaporator harness at the mother board and every time the motor change speed the voltage increased i repl the board and also found the out was wire incorrectly check you outlet as well you can buy a tool to check the outlet if you don't know how to use the voltmeter but it has to be properly wired and grounded ok
Posted on Oct 30, 2008
This is a GE side by side model GSS201EPH WW
Posted on Oct 15, 2008
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
Not cooling
The clicking noise is the klixon on the compressor. It is probably a fault in the start relay, or the capacitor is duff. Worse scenario is the start winding in the compressor is burnt out. Do you know what Refrigerant the unit is running on.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Wind noise
I would check all window and door seals.
Mar 31, 2009 | 2006 GMC Envoy
Front End Noise, Chev Cavalier
It sounds like you have a bad c v or constant velocity joint. Look under the car next to the wheel look for a rubber accordian type unit, if the rubber is torn or lose the grease has escaped and damaged the joint. You can replace it yourself, but if your not mechanically inclined would say take it to a shop.
Mar 04, 2009 | 2004 Chevrolet Cavalier
Hearing wind and road noise from right front of car and sunroof.
check the seals the rubber around window has anyone put anything on top of your car open the sunroof check the inside as it closes / to move the sunroof up or down after resting there are bolts on ech side at front theat you can un bolt push up and tighten up/ thanks for using fix ya please rate my response thank you very much
Jan 30, 2009 | 2006 Jaguar XJ8
GE Stainless Steel side by side freezer noise
sputering and gurgling is a common complaint with lots of models. it is the surculation of the refrigerant thew the evapurator tubing behind the rear wall. make shure the units condensor underneathe the fridge is clean and clear of dust. it can cause the head preasure from the compressor to increase witch can cause excesive sound in circulation. hope this helps you
Oct 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Driver Window
Sounds like a motor, or a s stuck mechanism. Either way the door panel must come off and this is no easy task.
Aug 04, 2008 | 2001 Ford Explorer Sport Trac
GE GSS20IEP Side by Side Refrigerator Logo
252 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
