Question about Seagate Computers & Internet
Perfectrecoverycard My 80GB Seagate Barracuda HD undergone series of reformatting. It was a mistake when I deleted the partition drives. Eventually, whenever i turn on my PC, perfectrecoverycard appears first on the screen before proceeding to the Windows. The screen shows three options: 1. Install perfect recovery card; 2. (Somewhat like) Configure Booting Devices and; 3. Install Later. I tried to Install but in the screen appears Analyzing disk... but never ends even I waited for 24 hours. I tried to click other options but I mistakenly deleted the OS. Now I cannot install the Operating System anymore. It won't boot anymore because perfectrecoverycard first appears on the screen so it wud'nt proceed to booting. PLease give me a detailed to do's. I realy appreciate your kindness and I would be so grateful to hear some instructions from your expertise. Thanks and Godbless. My email: marlcomi@yahoo.com
  • marlcomi Oct 14, 2008
    I appreciate your help but unfortunately I find it inappropriate. I cannot open the windows anymore because the first thing that apears on my screen is the Perfectrecoverycard. Therefore there is no way for me to click nor run anything nor boot from it. I wish I could hear some more suggestions from you. Thank you very much
    THank you very much kylemc1985, I will try it as soon as I get home. I was outside at the moment. Thanks again and God bless..
    Problem Solver:
  • 12 Answers
Hi there. The issue you are having is due to a modified MBR. You need to do the following:
  1. First of all, you need to have your Windows Administrator password handy. Since this doesn't apply to you, you can skip it. If you don't have it, it may still ask for it, you will have to reset it. This may be difficult but it may work for you. To reset this password, go to Start > Run. Type "control userpasswords2" without the quotation marks. Once you are in, select "Administrator", then "Reset Password". Reset this password to something you will remember. OK everything and prepare for the fun.
  2. Insert your Windows CD. Boot from it. Once you are booted to it, you will be at a menu with three options: Install... Repair... Quit. Select the Repair option. You may be asked if you want to use the Automated Repair Disk or Recovery Console. Select the option for Recovery Console.
  3. You will now enter a Command Based environment. Similar to DOS actually but more powerful. This is the Recovery Console. When you enter, you may be asked to select the Windows installation of choice. Select your Windows installation. If it asks for the Administrator password, enter it. If it was XP Home, it's most likely a blank password.
  4. Once you log in, type the following command: FIXMBR (Note: If it asks to continue, say yes. This will delete the old MBR and create a new one).
  5. Once this command completes, use this comand: FIXBOOT (Note: This will create a new Boot record. The old one has been torched by the FIXMBR so this will create a new one for you).
  6. Once done, type exit and try reinstalling your OS. This should help you out.
Good Luck and Have Fun.
Posted on Oct 14, 2008
  • kylemc1985
    kylemc1985 Oct 14, 2008
    Hi there. You have to boot off the Windows Installation CD to be able to do those steps. Administrator password won't apply whereas you have no bootable OS. However, once you boot the CD (Just insert the disc before system boot-up. You'll see "Press any key to boot from CD..." appear on screen for around 3-5 seconds, just hit any key.) you'll be able to continue from step 2 and forward.
    If the CD doesn't boot up right away, you will have to make CMOS setting changes. Just enter your CMOS Setup, go to the Boot section, and set CDROM as the first bootable drive.
    Hope This Helps. If not, I'll see if I can get a few screenshots provided for you. :-)
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
Can i reformat a xbox 360 seagate harddrive to windows xp??
Yes, your can format the hard drive and install Windows this drive
If you have the Windows XP disk it will partition the drive also
The drive must be fully formatted to work properly.
Sep 23, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Nov 25, 2009 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
I just split my HD and formatted Dr C:\ to fat32, D:\ would not
You cannot convert from NTFS to FAT32 unless you use say Partition Magic or other disk util.
If you have nothing in that partition then reformat it to FAT32 by right clicking on it and selecting > format> then select FAT32
Aug 10, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
I cannot install windows xp sp2 on my seagate barracuda 72000.10 500gb hard drive
I would suggest you go to the seagate website and download and burn out their hard drive test. run the test from boot and see if it detects a bad hard drive after it runs
Jul 11, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
New hard drive 160 GB ATA can't be partitioned
why dont you try 40000 in the first partitioned..if doesn't work.. try fix your hard drive using a seatools, a bootable disk, that can detect and repair a bad sector for a hard drive..
Feb 26, 2008 | Computers & Internet
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Sep 24, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Computers & Internet Logo
118 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
