Question about Microwave Ovens
Microwave makes a strange humming noise when it is working - sounds like a vibration of some kind. Does not always happen. Somethings it starts once the microwave has been running for a few seconds. Have a spacesaver GE built in microwave over my stove.
  • Microwave Ovens Master
  • 9,098 Answers
Assuming nothing's loose (such as from past repair attempt) then it may be the magnetron failing.
Your best bet is to keep using but (as always) do not leave it unattended while it's running.
Then if things get worse in some way, that would be a harder failure that can be assessed more easily.
If you are close to the end of the warranty period (1 year parts & labor or 9-year magnetron, e.g.) I would not wait past then.
GE Customer Service is here if you would prefer service now and want to find your nearest GE-authorized servicer.
Posted on Oct 20, 2008
I have a GE microwave jvm2070bh02 that is not heating and the motor/blower sounds really loud
It's had it's day and is worn out best get down to Walmart and git yerself a new one for around $100.
Feb 04, 2018 | Microwave Ovens
Microwave buzzes when off
This is the power transformer humming, sometimes when transformers get older you get vibrations in the windings due to magnetic fields generated within the transformer which causes the humming noise, It's more annoying than anything and won't affect the operation of the microwave.
Mar 06, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
When you press start the microwave starts with a low hum and sounds like a bearing or fan is vibrating, micrwave still heats up and works just runs rough. Bruce
Ther is a loose peace of metal in the magnetron, it is not a big worry, it's just noisy, i have a noisy microwave and it is working fine for 10 years now, if you use the defrosting mode you should hear the noise (on and off) because in the defrost mode the magnetron energises on and off, it could be the cabinet vibrating as well look for loose peaces of metal
Jan 04, 2011 | GE JVM1850 1000 Watts Microwave Oven
This is a Microwave GE Spacemaker over the range model JVM1428BHC01 The RangeHood functionality seems to have a constant air flow. It started to make a noise like an electric motor that rattles,...
this sounds more like a loose winding in the main coil to me,,if its humming? the noise is becouse steel core is vibrating,,,if this is so then the coil wont last very long,,,and it cant be fixed! all you can do is fit a new coil,,,,and thats not worth the cost!! go for a new unit,,,
Aug 08, 2010 | Microwave Ovens
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
Jul 16, 2009 | Microwave Ovens
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
Scary buzzing sound, no heat
The scary noise is coming from the transformer (big heavy steel thing under the magnatron) that steps up the voltage for it. Something is overloading it causing it to have way too big of a magnetic field causing it to vibrate so much it makes noise. Since you have ruled out the magnatron (which almost always is the culprit) it could be the high voltage diode, or high voltage cap (more likely). Replace those two and it should work. Microwaves are nice to work on cause its a simple circuit and they usually give you a schematic pasted on the inside.
Jan 01, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
315 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
