Question about Sony Handycam CCD-TR416 Camcorder
Can not eject tape
I have a Sony TRV-16 that had a tape stuck in it. I tried to eject it and the tape only came out half way. I turned it off and tried to eject again but the tape went back in the camera and now it will not eject at all. Please I need to get the tape out of the camera.HELP!!!!!
  • plubri Oct 16, 2008
    No puedo sacar la pelicula
  • wpalmisano Nov 18, 2008
    Yep, same problem. Sony repair service wants $211.00 just to look at it. They are not very good at customer relations, I think their service center sucks.
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Posted on Jan 23, 2009
  • Emungai Oct 17, 2011
    Thanks alot. It actually worked for me.
    I have a jvc camcorder which had the tape stuck inside.
    I followed your guidelines twice and just assisted it a bit then it popped out.
    I just realized that there was a problem with the tape itself.
Works great, except I also held down the eject button as soon as connected the AC - thanx
Posted on Jan 27, 2010
SOURCE:
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony CCD-TRV85. Tape Stuck - C31:22.
my guess is that there is a problem with the tape. Does it work with other tapes? Or haven't you tried?
Aug 23, 2009 | Sony Handycam CCD-TRV37 Camcorder
Eject problem SOny TRV-110E
The vlatch to spring the basket (cassette holder) is easy to access on these. Many times the eject process will take place if the holder is released. After the door is removed the holder can be released by gentley raising the latch on the right side of the holder assembly. After the tape is out further checks can be made for damp drum or tension issues.
Jul 21, 2009 | Sony Handycam DCR-TRV460E Digital...
DVR TRV-27 is showing error C:32:11
The problem is a rubber tape tension roller. Simply eject the tape, look inside where the tape goes. You will see a black rubber cylinder that may have a white plastic tube protruding. If you have long tweezer or a hemostat remove the plastic tube which hold the rubber tensioner in place, then remove the rubber tension cylinder. Clean the shaft of the black rubber tensioner with alcohol on a q-tip. Replace rubber tension cylinder and plastic tube.
Also, the tapes can cause the problem. This process is possible by one person, but you may need another person or have three hands. The C:31:23 is tape tension error. The tape has become stuck. Simply eject the tape. Holding the tape upside down, pull back on the tape cover release slide on the left side of the tape, now take the hemostat and push the tape release tab, located opposite of the tape cover, push this tab down and back toward the back edge of the tape. Now while holding both those release levers, take a pencil and wind the tape past the bad spot or until the tape winds freely.
I did both of these and was able to use the camera again and view all my tapes!
Good luck and QUIT SPANKING YOUR CAMERAS!!!!
May 01, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Tape won't eject from CCD-TRV608
There is a little plastic piece on the tape and it is getting stuck, you have to maually move this piece, witha paper clip or something else. it might break the piece off, but that is the only way I know to get it out.
Dec 18, 2008 | Sony Handycam CCD-TRV608 Camcorder
Tape will not eject
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to elect the tape. The error code you are getting indicates the reels are not turning for some reason. You can ssist the reels turning as the tape is ejected if you have a small plastic pick or a toothpick into the reels to assist the reels turning and tehn you may be able to remove the tape.
Sony 8mm TRV 530 Camera
That icon means u have a jammed or bad 8mm tape in the unit its telling u to eject tape.
Oct 27, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
Code 3L117C ???
None that I could find. Trash time for this Sony
Dec 10, 2007 | Sony SLV-798HF VHS VCR
Tape will not eject
This mceahnism is now defective and only a skilled workshop technician can do this job. If you need the service manual and parts we can help. Siva videolabs@gmail.com
Jan 03, 2007 | Sony Handycam CCD-TRV37 Camcorder
Problems ejecting a tape
Take to a decent camera shop, they probably won't charge fr pulling it out, if it can be done w/o disassembly. They could also give you a better idea on the problem at hand, and you'll be able to make a more informed decision. It could be something small stuck in the teeth of the gears and jamming it. Good luck
Jun 19, 2006 | Sony Handycam DCR-PC3 Mini DV Digital...
Sony Handycam CCD-TR416 Camcorder Logo
944 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
