I have a 46" Mitsubishi HDTV Model WT46805 purchased in 2000. There is something wrong with the color. There is generally no color at all. Every now and then the color will come on for a minute but very rarely. Sometimes there are red horizontal lines that come and go as well. How can I fix this problem?
  • lebrenns Oct 15, 2008
    The color on my 2000 Mitsubishi 46" HDTV Model WT46805 is not functioning properly. The color is virtually gone. There are no lines in the t.v., just the color is off. We have tried adjusting the convergence but it does not help. Any recommendations?
  • 905 Answers
The color IC's and the conversion chip plus the vertical deflection IC's all should be replaced!
you have more than one condition going on and those chips and ic's control color , color alignment , vertical and horizontal and will eventually cause the TV to shut down
you should have these replaced soon! or if you need help and have soldering experience I can help you identify and replace these IC's
Posted on Oct 15, 2008
  • jason Oct 15, 2008
    THIS IS A PROJECTION TV
    Genius:
  • 1,124 Answers
Based on your description the problem has to do with the main video processing Integrated Circuit and will need to be replaced.
  • 19,396 Answers
Check all cables at the back, Cables are the main cause for B&W only on plasma TVs. Seeplasma TV black and white now
IfTV is B&W and does not depends on cables, check the colorcalibration settings, if color has saturation set to 0% then thepicture will appear in black and white. Try using auto calibration, auto color, auto focus, depending on the model.
If the cables and calibration are ok it can be a problem with color burst separator circuitry, or with the signal board.
Try using the a
If the guaranty is expired, you can get a warranty extension and have it repaired, see here: Get a Warranty Extension
    Scholar:
  • 136 Answers
Yes you your self can fix this.
its the problem either of convergence settings or the convergence IC on the main power supply board is gone faulty.
for settings click this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
for IC click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
Posted on Oct 14, 2008
  • ready2helpu Oct 14, 2008
    feel free for any further assistance and queries.
    rate the solution if helped by it.
    thanks.
Mitsubishi model wt46805, green light on power button, no picture or sound. 1-2 error code, no errors detected. Is it worth fixing?
maybe or maybe not, I have a very important question or two, unplug set and try to turn on again, unplugging clears error buffer.
Have you or do you know what Glycol is and have here looked for signs of it?
Before you rate this information let me know what you find and if you have questions comment here as I am here to help.
SD TECH
Jul 15, 2011 | Mitsubishi WT-46805 46" Rear Projection...
I have a WT46805 and the color is fine for standard video input, but the when same video content is sent in through the HD input, the resolution is fantastic but the color is almost a monochromatic green. ...
While you are in the HD input look in the TV's menu, I think it is in video settings for a setting for RGB or Y, Pr, Pb. If it is set to RGB you will get that green picture. If you are not in the HD input that setting will not show up in the menu.
Apr 09, 2011 | Mitsubishi VS-60805 60" Rear Projection...
Have a sony 46 inch rear projection model #kp 46wt510! Purchased it new in 2004! Have nothing but great things to say about picture untill today! I have a color seperation with red, whatever line or...
This is problem of convergence output chips failure and it is fixable.
Replacement of convergence output chips on D board will solve tv problem, local tv repairman will do this job because convergence output chips replacement requires soldering work on circuit board.
Thanks.
Jan 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Need a power transformer for mits wt46805
that model does not use a power transformer, all voltages are from main supply and scan derived ones.
Do us both a favor and tell me what set is doing or not doing?
SD TECH
Nov 05, 2010 | Mitsubishi WT-46805 46" Rear Projection...
Black line down the side of both sides of the screen about two inches from either side
mitsubishi covers this problem under ext mfg warranty for two years after date of purchase 1800 332 2119
Feb 27, 2010 | Mitsubishi LT-46144 46 in. LCD HDTV
No picture and high pitch sound. I have already replace the bulb
This will give you the general idea, although it's not for your model. They're all generally the same.
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 08, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Hi there...I have mitsubishi WD-73927 manufacture
If your TV is DLP , Then your Light engine is Bad,when color changes and little spots appear it is light engine.
Aug 19, 2009 | Mitsubishi WD73727 73" HDTV
Mitsubishi LT46-144 LCD Verticle Line Problem
Go to Mitsubishi support page, look at warranties (scroll down) and see if your model is under the extended warranty section. Then if so have a tech repair person come look at the picture and order the parts while you keep the tv. Parts and labor are covered.
Mar 14, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Toshiba dlp
The light engine part number is 234054 and cost $456.00
Dec 20, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
Top Televison & Video Experts
