Question about Mitsubishi WD-62525 62" Rear Projection HDTV
DM PCB Nipper00, where is the DM PCB located in the back of the tv and what does it look like? thank you.
  • 80 Answers
The DM pcb is located on the left side of the back - you will see a little fan it is under it - it will be the middle board - on the left is the signal anf the right is the FMT - on your model you will need to do the caps on the FMT pcb also caps c8f19 - c8f21 - c8f22 - cf827
replace all of them with part # 181P734030 (680 uFD, 16V, 105C). or equal - also check the power pcb the one toward the front of the dm (power cord is on it) if you see any caps with the top pushed out (not flat) replace them.
Thanks
Scott
Posted on Oct 16, 2008
On my WS-55511 TV, after a power interruption, will not power up. All i get is a continuos blinking green light.I tried unpluging the tv several times, no luck.
Good Day,
LED does not stop blinking after plug in. Check for 12 volts at connect or PF pin 10 and 28 volts at connector PF pin 11, (on the board on the right hand side, but on the left side of board towards the back of TV). If the supplies are correct suspect a problem in the DM Assembly (part # 955C230002). Part is not available for replacement.
Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 UFD, 16V, 105C) on the DM Power PCB located within the DM Assembly. If they are bad or not, replace them all with part # 181P734030 (680 UFD, 16V, 105C).
The DM (Digital Module) Assembly is located on the extreme left of the chassis from the back. It is standing in a vertical position. Remove cover and you see the Cap’s in one corner of the inside PCB.
Good Luck, Big IRISH.
Dec 14, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Dm board (power supply) for mitsubishi rear projection tv (ws-55807)
Good day,
mohiuddin;
If the indicator stays on then you may have an DM PCB problem and to correct this do the the folowing:
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 22, 2008 | Mitsubishi WS-55807 TV
My tv
Good Day, fidel59;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
Jul 15, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Need a repair solution e-mailed
Good Day, jnjetsn;
Jul 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green light
Good Day, pipe filtr;
Mitsubishi power board pcb post
Good day, steve sc;
The DM board is normanlly on the left side TV looking from the back. It has a shield around it, remove. The caps are big and black, they look the replacements(only ones on board). Here's what says about this issue:
If the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). (LED does not stop blinking after plug in) On the DM
Good Luck, big IRISH. ps hope this helpful!
PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
It is not an easy job, it will take some time but since you have it apart there is another problem that will accure so might as well do this too:
Tile or block pattern with no video or OSD. Check D8F00 and D8F01 part # 264P828010, also check C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002).
All the parts have location numbers like C8F29 that will tell you what and where these parts are.
Good luck, big IRISH.
Jul 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
Good Day, nixonam;
Blinkink light
Good Day, jcarnell;
Jul 05, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
151 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
