Question about Whirlpool Duet GHW9150P Front Load Washer
Duet washer start washer runs a min flashes code f-20
  • 958 Answers
F-20 stands for the error no water coming in. but there is actual water coming in. so the problem is the flow meter.
it is not detecting that there is water flowing unto it. if the unit is new and still under warranty, they would replace it. if not, then check the alignment of the unit. if it is tilted or change it's orientation with the horizontal, the flow meter would sometimes stuck and would not send the correct signal to the controller.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My front load has a f 6 code flashing
F06 is an error code that meansthat the control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1goJUbb8i
Dec 05, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer won't start, control lock lite on?
Try unplugging the washer for 30 minutes. When you plug it back in, the power board should reset and allow you to start a new wash cycle.
Oct 25, 2011 | Whirlpool GHW9300 Duet Washer
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER RUNS FOR 1-2 MINUTES, THEN STOPS & STARTS FLASHING H/F
can u switch of hte michine at the wall and leave it for 20 mins and turn it on again
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT GWH9300P Suds then F2
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washer trouble codes
F21 is a drain error code. You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump.
Remove the #20 torx screw out of there to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to turn counter clockwise. So after placing something underneath to catch
the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails,
screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and
you don't have any leaks. Put your panel back in and you're ready to go.
Please make sure you post a rating if this solution was helpful.
Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Model #WFW8300SW Error code F then 20, what does it mean ?
does it do this a lot dont rate me till were done give me your complete model number
Jan 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
