Question about Apple InFocus X1 Multimedia Projector
Infocus X1 lighting problem
My X1 has worked very well until I finally had it mounted (upside down) from a ceiling mount. Since then the bulb inconsistently turns on. I tried replacing the bulb and that has not solved the problem.
At times, I have been able to put some pressure (pushing up) on the projector and been able to get it to light up.
Seems like I have a short somewhere due to my ability to put pressure or squeeze the projector and that enables the projector to stike up the bulb.
Seen any problems like this after an X1 has been placed on a ceiling mount?
    Scholar:
  • 167 Answers
Well there are only a couple of things that could cause this problem. However considering this all started when it was mounted consider the possibility you may have used screws that are too long and are is/are subsequently shorting something out.
Cheers
Posted on Dec 30, 2009
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
The image from the InFocus is upside down. Do not have a users manual. thanx, mike
In the main menu, go to Settings, select System, and uncheck Ceiling (that setting is to allow it to be mounted upside down from a ceiling mount).
Aug 10, 2010 | InFocus X1a DLP Projector
Ceining Mounting
in the menu (settings) change the image orientation.
May 10, 2010 | InFocus IN5102 LCD Projector
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Image is upside down
Hit the menu/select button to bring up the menu either on the projector or on the projector remote then go down until advanced is highlighted then press the menu/select button then move down until Ceiling Project is highlighted and hit the menu/select button again to get the image right side up. If you have the manual for the projector this information can be found on page 34.
Dec 09, 2008 | InFocus LP 530 Multimedia Projector
Need to invert the picture--ceiling mounted
The SYSTEM menu provides options for ceiling mount and rear projection. From the main menu, select SYSTEM, move the cursor down to CEILING and then click the SELECT button. That should put a check mark on that option. Then go to PREVIOUS and finally EXIT the menu,
Aug 19, 2008 | InFocus ScreenPlay 4805 Multimedia...
Apple InFocus X1 Multimedia Projector Logo
163 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
