Question about Acer AMERICA AM1640 PDC/1.8 2GB 250G-DVDR LAN MODEM WVHP PC Desktop
Acer am1640 freezing problem
Ok i start my computer up and when ever i run any program the computer will freeze and i cant figure out if i have a virus or if there is some internal problem
i have run ccleaner/jkdefrag/chkdsk/and disk defrag and none seem to help
my system specs are
1.8ghz dual core
250gb hdd
256mb vid card
vista home prem
  • Alterran Oct 14, 2008
    no im pretty smart with computers and i use smart close and this was after i closed all unnecessary
    programs and it still happens
  • thekid149 Jan 06, 2009
    YO pal i got same computer same problem u got wireless net me too the net is freezing my comp take it out and everything will be good im trying everything to fix dat problem wen i do ill notify u
    Novelist:
    Scholar:
  • 141 Answers
See if you can check the temperature of your system in the bios. Check when you first boot up and after it freezes restart/ go into the bios and check it again. One thing overheating does is freeze up or shut down your pc. Could also be a virus. Also delete all your temp files/ internet temp files too. Check your memory if you don't find the problem here. A good way to control your system resources is to go to start/ run/ type "msconfig"/ enter. Check "selective start up"/ click on the "startup" tab on top right. You can almost safely un-check everything except your AntiVirus software depending on your pc unless you have a lap. Then your would need to leave things like the keyboard closure, touch pad etc. checked. This will take away any doubt that it may be a software conflict or to many programs trying to open at once causing your crash.
Good luck!!!
Posted on Oct 14, 2008
  • 749 Answers
Hit start-run- type in MSCONFIG - select the startup tab - uncheck all the boxes - restart the computer . you will get a message saying you used the utility to change the way windows starts, this is normal , check the lil box that tells it not to bother you again and then ok. let me know if you need more help.. please rate ..
Very slow, freezes, jams, and is non responsive, I have to take battery out and wait for a an hour before putting battery in laptop, my computer is an acer 2350 travelmate, also when I bought this in...
This sounds like either a hard drive problem, when you power on the laptop there should be an option to enter BIOS or Setup (usually F2) once inside of the BIOS you should be able to run a diagnostic. and that will tell you if there is anything wrong with the hardware. If everything passes that test. you may have some serious Virus problems.
May 04, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
My laptop will just randomly turn off...it will run well for a few minutes and then just turn off and everytime i try to start it over it turns off even quicker...within a minute or two...i realy need help...
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Nov 02, 2010 | Acer Aspire 5315 Notebook
Freezes after few minutes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
Why do i have to reboot 4 or 5 times to get it to work?
This is probably done to the bios on start up you will need to load new bios when you get connected
May 09, 2010 | Acer Aspire One PC Notebook
Froze. very slow. very hot
Sounds to me like the cpu fan,has died and the cpu is overheating causing the freeze, the slow running, and the excessive heat. the cpu is probably fried.
Jul 12, 2009 | HP Pavilion dv6000z Notebook
Acer AL1917A monitor freeze
acer al1917 go blank when change program
Apr 24, 2009 | Acer AL1917AS (Black, Silver) LCD Monitor
Acer AMERICA AM1640 PDC/1.8 2GB 250G-DVDR LAN MODEM WVHP  PC Desktop Logo
141 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
