Question about JVC Audio Players & Recorders
JVC DVD DIGITAL THEATER SYSTEM TH-M505
UNABLE TO OPEN DISK TRAY. DISPLAY SAYS LOCKED. HOW DO I UNLOCK IT?
bluenadas
  • 203 Answers
SOURCE: how do i unlock my jvc th-m505 dvd digital theater system?
Hold the STOP button and push the EJECT button.
Posted on Jun 15, 2007
SOURCE: jvc th m505
instruction book says: on the center unit ONLY WHILE UNIT IS OFF there is a button with a square under it (on top of unit) press & hold also press & hold disc 1 eject button (arrow pointing up). The system turns on & "UNLOCK" appears on the display window.
Posted on Jun 19, 2008
SOURCE: JVC th-m505 and dish network box sound level control problem
It's not your receiver, it's the Dish Network equipment, I have the same issue with my Onkyo...unfortunately I'm still researching the solution.
Posted on Nov 26, 2008
  • 52 Answers
SOURCE: Hello,
If the JVC m606 requires a stipped wire to connect them then they should be fine just make sure you connect the right speaker to the proper output if your speakers have a specified connector on the end then you would have to cut that off and strip the wire. if your m606 requires a specified connector for the speakers then you would have to change the connectors out for the proper ones.
Posted on Mar 07, 2009
  • 22 Answers
SOURCE: Connect IPOD to JVC TH-M505 Theater System
http://www.superwarehouse.com/Cables_to_Go_iPod_Audio_Cable/35508/p/1492128
the above cable will allow you to plug your ipod into the audio in on the stereo
Posted on Jun 13, 2009
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Jun 17, 2009 | JVC TH-M303 System
Jvc dvd TH-C6 says locked and dvd wont eject
While the system is off
Press and hold the stop button and disc one open tray button at same time
It will say unlocked and then power up and you are good to go
Hope this helps i just unlocked mine got info from jvc user manual on website this link is the pdf
http://resources.jvc.com/Resources/00/00/95/LVT1147-001C.pdf
Jan 15, 2009 | JVC TH-M505 System
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
JVC TH-M505 changer displays NO DISC
There are two rails in the dvd player. I have found that cleaning the rails & applying new grease to them usually solves the problem. a spray with silcone will do. do not get any on the laser. best done by a pro & not many know of this little trick.
Miyagi2
Jun 10, 2008 | JVC TH-M505 System
Jvc th m505
May 27, 2008 | JVC TH-M505 System
Jvc player wont open door its saying locked
I cannot unlock my JVC DVD player the work lock appears in the window
Nov 11, 2007 | JVC TH-M505 System
How do i unlock my jvc th-m505 dvd digital theater system?
May 15, 2007 | JVC TH-M505 System
202 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
