Sir help Me with my Compaq MV520 monitor the power led flashing orange to green and vice versa
Sir if i plug my compaq mv520 into AC outlet and I turn it ON the power led flashing orange to green color and vice versa and I turn it OFF back then I connect into The system Unit and I turn ON the Systen Unit as well as the monitor and I found out that the power led stop flashing but from green turn into orange which is stand By Mode.Sir My System Unit have no problem because I try it into other monitor it works fine So the problem is in my monitor.Sir it is posible that the problem is in the Power Supply of the monitor? Help me Find out sir,Thanks in advance!!!
  • 1 more comment
  • neiljopia Oct 14, 2008
    Thank you sir but what is a backlight inveter?Is it in the Power Supply Section?
    sir it is also posible that I have a bad transistor K2645 or KSP44 or IC KA3842B? Sir You have a schematic diagram of Compaq Monitor MV520?
  • neiljopia Oct 15, 2008
    Thank very much Sir MABUHAY!!!!!!
    Champion:
  • 293 Answers
Hi..there! Sir Neil:
You're right... Your backlight inverter are busted. Need to replaced a new one or repaired it.
Posted on Oct 14, 2008
  • Cj T
    Cj T Oct 14, 2008
    Yeah...sure, It's a piece of component with built-in power supply. You'll need to replaced the capacitors. Look for any bad caps with a bulged on top. Not sure... just replaced all the caps.:)
  • Cj T
    Cj T Oct 14, 2008
    Sorry, I don't... that you have to checked with a meter yourself.
My microphone suddenly stop working on my compaq mv520 monitor. can you tel me what can i do to fix it?
Try deinstalling the mic and redownload and install fresh driver see how that goes should clear up any glich
Dec 30, 2009 | Compaq S510 15" Color Monitor
Flashing power lights green and amber will not power up
Try removeing the battery form the laptop and using just AC porwer. if it still fails you may need to replace the motherboard. :(
Sep 14, 2009 | Compaq Armada M700 Notebook
Lost of colors
crt base dray soldrin, rgb vga cable 15" pin connector problem
Apr 07, 2009 | Computers & Internet
Problem with compaq MV 520 monitor
Your monitor is operating normally. After Windows starts it is setting the video resolution to something outside of the monitor's range. That's why you see the Windows splash screen, then the message from the monitor about the settings. Most likely the computer was used before with a monitor that had a wider range of resolutions available.
Restart the computer. When the manufacturer's logo screen appears, press the F8 key three or four times. This should get you a startup menu screen. Pick the option of starting in VGA mode, and Windows will start with video settings that your monitor supports.
Feb 01, 2009 | Compaq MV 520 Monitor
Schematic diagram
plz send me philips lcd monitor diagram power supply model 150B
thanks
regards
asif mansouri
Oct 20, 2008 | Computers & Internet
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Pb avec le son
Dear Sir,
Ihave a COMPAQ PRESSARIO Computer model MV520. Lately I am getting lines on the screen at the bottom. Suggest the remedy.
K.S.Bajaj
Jun 16, 2008 | Compaq Presario X1000 Notebook
Help for compaq mv520
Here is what you have been asking. q901 --- K2645 q902 --- KSP44 u90 --- uc 3842P It seems you problem is in the power supply switching circuit. I hope this will solve your problem. Please let me know if this has solved your problem junr7
Aug 25, 2007 | Compaq MV 540 15" CRT Monitor
Computers & Internet Logo
611 people viewed this question
David Payne
David Payne
