Question about Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each
Phantom 3 wheel scooter back-up alarm
My mother-in-law has a Phantom 3-wheel Scooter (blue) and would like me to disable the back-up alarm. The assisted care facility where she lives is loaded with similar medical transport devices and she seems to be the only one with this annoying feature operating. I would like to find a wiring schematic for the scooter--I have the necessary skills; just need the diagrams.
Dave G
  • jrtagility Oct 16, 2008
    Thank you for your assistance; however I have determined that the sound resonates from the control module located under the floorboard panel. I am attempting to resolve this without disassembling the module. What I'm looking for is the wiring details that will allow me to specifically disable the horn/reverse alarm electrically.
  • Anonymous Dec 01, 2008
    Had the same problem with my mother in the home. Under the feet is a panel. The alarm is under there. I used cotton and electrical tape to shut it up. Did not cut any wires figuring I'd be selling it later. *****, CA
Easy fix; pull the floor board off by removing the 2 phillips screws. There is a round, black piezo with 2 wires connecting it; a red wire, and a black wire. Cut either of the wires, and then tape both ends of the cut wire to prevent it from grounding out on something. No more annoying noise. To hook it back up, shave the wire's insulation back and connect the wires again, but I don't know why anyone would want that installed again; I guess so someone doesn't back over a dump truck in the scooter ;).
I think the funniest thing (April Fools Day Prank) to do with that damn alarm would be to hook it up to a toilet seat lid, but in a way that the alarm only goes off when the seat is lowered, so if someone had to take a dump, they'd have to listen to the alarm...this might keep employees from taking 30 min bathroom breaks ;)
Posted on Mar 02, 2009
Should the piezo be located on the circuit board, a wiring diagram will not be of use since it is probably an ASIC (uProcessor) controlled circuit and the piezo device will be located within the control module on the board. In this case, a soldering iron will be beneficial to actually desolder the two leads from the PCB. However, you could be very lucky and find the piezo device having two wires and positioned off from the PCB. At this point, all you would have to do is clip one wire.
No matter what, once you disturb [remove/desolder] the piezo device, you will no longer have any sound whatsoever. If you want, you can take a picture of the open module and send the file to me: Marc
[at] engineersandbox [dot]tttttttttttttttttttttt com.
Posted on Oct 16, 2008
    Novelist:
  • 130 Answers
Dave, simply find the little black disk or box... simple piezo-electric device. Listen for the sound and go from there. Possibly the piezo is located in the controls within the handset region.
Posted on Oct 15, 2008
Disable back-up warning on Drive Phantom Scooter
Most of these units have the back up buzzer shrink-wrapped together in the wiring harness under the rear shroud. aka motor cover. The buzzer is typically between the size of a 25 and 50 cent piece, is black and has two very small wires coming out of it - one red and one black. You can cut one wire where you can reconnect it later - just in case you cut the wrong wire!
Dec 09, 2011 | Drive Medical Phantom 3 Wheel Scooter, Red
I have a Dr.k scooter and the charger say it's full but it wont go
My 94 year old mother has Dr. K. Drive scooter (f66) 0511232 4067
Battery Pack S/N: 0521323 Model: HP-1202B. Her Great Great Children have misplaced the key. As Mother is no longer able to stand, I need to order a key so we can go for walk. Where do I order a key?
Patt
May 29, 2011 | Drive Medical Mini Phantom Three Wheel...
My Dad just passed away and his Dr. K Phantom 3 wheel scooter won't run. When I plug the charger in, it says its fully charged. When I unplug it..it reads E..I want to donate this to a nursing home locally...
tar the batteries are probably too low to charge with the scooter charger and need to be replaced. With the charger plugged in it will indicate a full charge beacuse its reading the output of the charger but when you unplug it the batteries are too low to indicate any voltage. hope this helps you
Apr 10, 2011 | Drive Medical Mini Phantom Three Wheel...
Batteries won't charge
Hi. Sounds like there is a faulty connection somewhere between the charger and the batteries. Are the batteries connected correctly. The charger uses the voltage level in the batteries to regulate itself. If there is a faulty connection, then the charge will not operate. Use a multi-meter to check if the batteries are connected correctly. There should be 24 to 26 volts across both batteries.
This fault can also be caused by a faulty charger socket. Check for any signs of melting or heat damage. There might also be a disconnected wire in the plug on the charger itself.Good luck. Neil.
May 29, 2010 | Drive Medical BLUE 3 Wheel Compact Mini...
Where can I order parts for the drive medical Phantom scooter? the on/off switch needs replacing on my scooter and I can't find an outlet for ordering a part.
Hi is the on /off switch a proper key lock, or a round plug. If it is a round plug then the switch is probably a mono plug available from any radio repair shop. I have changed a few of these.
Is the name phantom a proper brand name, or just a name the importer put on it. Have a llok inside the covers and see if you can find another name, or a serial number sticker.
Good luck. Neil.
May 09, 2010 | Drive Medical Mini Phantom Three Wheel...
I have a celebrity pride mobility scooter and when u press the throttle nothing happens for about 10 seconds and then it jumps forward giving the mother in law the fright of her life. Do you think theres a...
if it is a delay in a connection,there has to be something delaying it,so have it checked by a qualified dealer or electrician if he is updated on the product.
Apr 27, 2010 | Drive Medical Mini Phantom Three Wheel...
Pride celebrity XL won't go.
Have you checked the motor brushes for wear and spring tension, sometimes the spring becomes brittle and breaks but can sometimes still make contact.
Regards Steve.
Sep 01, 2009 | Drive Medical Mini Phantom Three Wheel...
The battery is fully charged but the scooter will not move.
Is it the small portable scooter? The one with the base that comes apart for transporting? Could it be a bad connection where it goes back together?
If it is the portable, try disconnecting the rear drive portion from the base and re-installing it so it clicks into place.
Aug 31, 2009 | Drive Medical Mini Phantom Three Wheel...
Electric scooter Troubleshooting
A small tip here - bigger is better. The large diameter wheels clear gaps in concrete or pavement that would hang up a skate wheel or a scooter with smaller wheels. Most electric scooters also handle well in gravel and small terrain features. We don't recommend slamming electric scooters into a curb to get over it like some people do with their bike. This could result in damage to the electric scooter. Simply Ollie up a curb and keep going.
Aug 27, 2008 | Drive Medical Mini Phantom Three Wheel...
Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each Logo
524 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
