Question about Refrigerators
Refrigerator white westing house model WR2605D SS
ELectrolux two-door refrigerator..freezer is working but the lower portion is still warm.
SOURCE: side by side refrigerator problem GSH25KGRB WW
change its hearter mosty goes bad inGE refgrator
Posted on Feb 19, 2009
SOURCE: Freezer is cold but refrigerator is warm
defrost heater - reoplace with dual heaer assy - also good idea to replace defrost timer
Posted on Apr 22, 2009
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
Maytag317
  • 1136 Answers
SOURCE: I have a Kenmore refrigerator (model 253.63732300)
Hi, Check in the freezer section and see if there is frost building up on the rear panel. Notice if the evaporator fan motor is running. If there is frost, you need to repair the defrost cycle.
Please let me know if this what you find so I can assist you further.
Vic
Posted on Jun 14, 2009
  • 239 Answers
SOURCE: refrigerator will not cool
pull freezer back panel. is fan moving, is there frost built up on coils if so then defrost problem
Posted on Apr 25, 2010
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
How to lower freezer temperature
Not sure what you mean by the freezer too cold? The freezer section should be at or below 0 degrees C or 32 degree F. if its working properly. If the FF section is too warm and your temp control door or vent is at max cold either the vent is not moving (stuck in the closed position) or the fan in the freezer is not working.
Nov 10, 2014 | Frigidaire Refrigerators
Electrolux refrigerator not cooling
Is your freezer side working fine? If it is, and it is just the refrigerator portion of your appliance, then I would check the damper switch/door that is between the doors. The freezer actually sends its cool air into the refrigerator portion to help cool it.
Aug 20, 2012 | Electrolux EI26SS55GS Stainless Steel ...
Timer problem
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 18, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
Ice chute door hangs open ...kenmore 106.57904700
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side Maytag frig that is warm on top, not bottom
You can turn the thermostat off for now to let the ice thaw out, if a door was left open there might not be anything wrong, but if it freezes up again sounds like you might have a bad defrost heater or defrost limit. Hope this helps
Apr 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
Top portion of rrefrigerator on refrig side is hot
Check to see if refrigerator door is even with freezer door at top, or is it lower. If lower, the light switch may not be contacted fully. Remove toe plate , bottom front on fridge. Under refrigerator door bottom hinge is a threaded rod. Adjust this to raise door to make level.
Nov 20, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
