Question about Kenmore 57029 Side by Side Refrigerator
Side by side refrigerator and freezer not working, (fan not working either)
My side by side kenmore refrigerator stopped working. model 25351694102 manufactured 12/01. the fan stopped working and when i plug it in, the light turns on but it doesn't do anything else. it was working fine till this morning. the fan doesn't turn, and nothing cools, not the refrigerator nor the freezer and doesn't make any ice. its defrosted. i can't find a defroster button or anything? can you help me, please?
  • mariamadalen Jan 13, 2009
    My kenmore has the same problem it was not work for 4 years, now i plugged and all the lights come on but nothing is working, like freezer, refrigerator, nothing get cold
  • CTC911CTC Jan 28, 2009
    I have the same problem.
    The cooling fan on the bottom/back is running, the air from this fan is not hot/warm it is room temp.
    Internal to the Fridge (Freezer and Refridge) there is warm air blowing from the vents.
    The display is lit, though changing the selections does not seem to change the operation of the machine
    Is there a way to FORCE the compressor to run? Seems that all is well but the compressor
    Genius:
  • 1,036 Answers
This doesn't sound good does it?
The good news is that the compressor at the back, is probably fine, it's just waiting for the signal to turn on.
First, try adjusting the controls from minimum to maximum to see if you can get any life out of it.
If you have no power to the display, please state this.
If it does function - but not properly, please state this.
If there is no action at all, I suspect there is a fault on the main control board, or the motor run capacitor is faulty. With a faulty capacitor, you may get a 'click' when first turned on, and the compressor will buzz or get warm without actually cooling.
Hopefuly this will help, but please get back with more information.
Thank you.
Posted on Jan 01, 2009
Kenmore side by side refrigerator 58642891
depends on the AGE of the one you have needing repairs . FIXYA can not determine what you need to do .
Nov 14, 2017 | Kenmore 56563 Side by Side Refrigerator
My freezer is working great but my refrigerator is warm on my kenmore side by side refrigerator model # 59592992
Look for frost on the backside of the freezer. You might have a bad defrost heater. It could also be a bad evaporator fan motor.
May 06, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
The freezer fan runs continuosly
It may be because there is some air leak into the freezer. Check if it is closed air tight. Also try defrosting the freezer. Check the fan after that. It may stop working continuously.
Apr 21, 2010 | Kenmore 57029 Side by Side Refrigerator
I have a Kenmore side by side refrigerator, model 51673. The freezer works OK but the refrigerator side is NOT working. Advice?
It could possibly be the fan, located in the freezer compartment.  That blows the cold freezer air into the ducts that go to the refrigerator side.
Aug 25, 2009 | Refrigerators
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Kenmore refridgerator #25351694102
check for a lock button on dispencer controls
Aug 05, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore 57029 Side by Side Refrigerator Logo
127 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
