Question about HP Computers & Internet
On powering on'the screen remains black and the ethernet plug is flickering. no sound from the hard drive
    Novelist:
    Scholar:
  • 141 Answers
Get into your bios (usually by hitting del key as sys. is booting up). See if your hdd is detected in the settings. You can also put a screw driver on the hd (while pc running) with the handle end to your ear. You will be able to hear the drive spinning if it's working. If you don't hear it, detect it in bios or feel it spinning then try another "good" hard drive. A bad drive that's not working should give an error message like "no drive detected" or like that. Because you have a black screen (if no error messages) then I would check your power supply since you say your ethernet light is flickering. How about the sys. fan & cpu fan, are they working? Are other rom drives lighting up? It could be a few different things hopefully one of these will solve your problem.
Posted on Oct 14, 2008
    Problem Solver:
  • 52 Answers
The hard drive could have failed..Try a hard start to see if it will react. Do you get any beeps?? a warning beep or beeps may indicate a hard drive failure. Try to get into C-Mode set up. click alt/cntrl/del as you turn on the set.or alt/cntrl F10. Hard drive failures can happen if ther is to much written to the drive or just a plain 'Crash'.
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
The screen is black and the power light is flashing not constant and I don't think the hard drive is turning
If the screen remains black and does not show the BIOS window when powering up, coupled with the lack of hard drive power, then it sounds like you have a motherboard failure.
If your fans also do not come up, then that will confirm it.
Mar 09, 2010 | Computers & Internet
Screen went black...rebooted, computer seems to
Remove the battery and disconnect the power adapter for about a minute.
connect only the AC then boot it back up. If you can see the Compaq splash screen and still unable to load Windows, re install OS.
If you could not see the splash screen, too bad it could be a motherboard issue,
Hope this helps.
Dec 21, 2009 | Compaq Presario CQ60-220US PC Laptop
No picture, no sound, green light flicker ongoing
The power supply in the Tv has failed and should be looked at by a qualified technician.
Sep 09, 2009 | Samsung Televison & Video
Black screen on my a135 i turn it on it powers up runs the dvd drive but screen is black just like it is when it is off i does not flicker make a sound or nothing no matter what i do to it it does not...
Okay, this is unfortunately this is one of those times I call check the obvious first, so even though you have already thought of these things please check them again, first is the monitor plugged in? Is it on? Is the brightness up? Is the cable that connects the monitor to the computer plugged in? (That is usually the blue plug, or a tan plug). If you have verified that all of these things are in there correct place, I will need to know one more thing before I can continue troubleshooting. Is your monitor a Cathode-Ray Tube Monitor (Very big monitor that is usually associates with older computers) or LCD Monitor (Very thin).I will need to know this in order to continue troubleshooting.
Ryan Frame
Creative Energy Associates Technical Center
Aug 04, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Won't turn on, black screen
seems to be a hardware issue (not easy to diagnose over the net) I would take it into a shop and have it looked at.
May 28, 2009 | Dell Inspiron 1525 Notebook
Emachine locked up won't start
Hard Drive Clicking = Going Towards End Of Life
Put the hard drive in a working pc and get any important data off it , its about to die!!!!!!!
Get a new hard drive and do a windows reinstall (not like you have a choice)
not sure about the rest though sorry
Jan 04, 2009 | E-Machines eMachines Desktop PC
Disk no longer powers up
You may have a faulty power adapter, you need to check if it has +12volts & +5volts with a multimeter. You might be able to borrow a power adapter to test the drive before you pull it apart.
To test the hard drive.
Remove the hard drive from the case and connect it directly to the IDE cable (or SATA cable) and the power connector inside your computer. Depending whether the drive is on a IDE cabe on its own, then the jumper can be set to either Master or Slave.
If the drive is on the same cable as your existing hard drive then the 320Gb drive should be jumpered as a slave drive.
When you boot up your computer check the BIOS to see if it detects the 320Gb drive, if OK then let it boot up into Windows.
If you then click on My Computer you should see your C: drive as well as your 320Gb drive (might be D: drive). You should be able to Explore/view the files on this drive, if so the drive is OK then the power adapter or the hard drive USB box is faulty.
Dec 02, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Computers & Internet Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
