Question about Nikon Coolpix 4500 Digital Camera
Nikon coolpix 4500 uv lens
I would like to purhase a uv filter for nikon coolpix 4500
  • 64 Answers
I bought a 4 lens kit - I think from Amazon. It was a long time ago.
The size is 28mm.
yes, here it is
http://www.amazon.com/Nikon-28mm-Filter-Set-Coolpix/dp/B0000521B9
Posted on Dec 08, 2008
Will a Vivitar 58 mm UV filter attach to a Nikon d3100 18-55mm lens?
Not directly. The 18-55mm takes 52mm filters. However, you could purchase a 52-58 step-up ring to allow you to adapt the filter to the lens for significantly less money than a 52mm UV filter. One such adapter is http://www.adorama.com/IRXRA5852.html
Aug 03, 2011 | Vivitar Cameras
In the past when film was still king and I was using it I had always used a UV or a Polarized lens cover. Now in the DSLR world I've been told that I should not use a non rated DSLR lens cover. Is there...
Without specific reference to the D90, the following applies to almost all dSLR's: Skylight filters (UV) are fine, but avoid using auto white balance. Polarisers can prevent the autofocus system from working, but the more expensive circular polarisers are usually OK although don't produce quite the same effect as linear polarisers.
Oct 08, 2010 | Nikon DSLR D90 Digital Camera
Can you use a fisheye lens on the Nikon Coolpix P80
I do not think any company makes an Fisheye lens attachment for Nikon P80. This is a fixed lens camera.
If it is being manufactured by any 3rd party then Nikon then you can only attach it to the front of the P80's lens.
Caution. Nikon P80 is a super zoom and lens barrel is made up of plastic that is too light weight. Do not attach heavy peace of metal on the lens. it can only carry the filters.
Jun 08, 2010 | Nikon COOLPIX P80 Digital Camera
My D80 fell from a foot n half above the ground level well packed in a good quality carry case few days back.uv filter attached to 18-135 Nikor lens cracked & lens cap was jammed. After carefully...
Hi, allow me to suggest using another lens to see if you still see the dark patches in the top corners. If not it is the lens, if so it is the camera. Either way it sounds as though something is maladjusted. Call Nikon digital 1-800-645-6689.
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
My Nikon D40 18-55mm lens won't work on automatic
THERE is a problem in lens not with the UV filter
remove the lens clean the contact of lens & camera if not working repair or replace it
Jul 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon 4500 Coolpix
If u tried to hold up a 1000 lb weight what do u think would happen???
Well putting 12V into a 4V spicket will do the same thing.
Nov 09, 2008 | Nikon Coolpix 4500 Digital Camera
Coolpix 4500 lcd screen replacement
I have a lcd I just bought for L10 and it is the wrong one. It is for a 4200. If interested email me at theetrader@hotmail.com
Oct 31, 2007 | Nikon Coolpix 4600 Digital Camera
Image rings when using Coolpix for microscopy
Under some circumstances when using the Coolpix 4500 attached to a microscope concentric rings are visible as in the below. The COOLPIX 4500 aspherical lens surface is ground to create the ideal curves to gather rays at the focal point with an extremely high accuracy. Such minute lines are not visible in the image taken with a camera alone, however if the camera is used with a microscope, the lines become visible as the depth of field is increased due to the combined F numbers of the camera lens and microscope lenses.
Aug 30, 2005 | Nikon Coolpix 4500 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
137 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
