Gateway monitor will not work on non gateway PC.
I gave my father my old Gateway monitor #FPD1950 to use on his PC, he is running windows XP like myself. We disconnected his old CRT and hooked up the LCD with the analog cable as he does not have a digital port, and nothing but a blank screen. Is the cable different for CRT/ LCD connections? Maybe it is a software issue? How do I find the software on my computer and download it for him. Any ideas? Joe
  • 293 Answers
It's could be the backlight inverter are busted...try plugged to another PC. If it still the same problems... Replaced a new backlight inverter or repaired it.
Posted on Oct 14, 2008
try draging task bar down
Feb 05, 2013 | Gateway FPD1950
My roommates Father downloaded IE9 on his Gateway T-1631 Laptop, Now when he turns on the computer a screen pops up with " Error loading Operating System " before windows even loads, I tried...
sound like a registry prob best i could say is if you have a os disc then reboot it if not there are free 1z out there called tiny xp and tiny7 tiny7 is the best cos it will save your old os and docs in a folder called windows old
Apr 12, 2011 | Gateway Computers & Internet
My FPD1950 Gateway Monitor quit working. It will not go on..What can it be? What can be done to fix it?
It does the same on another PC?
First thing to look inside the monitor will be the DC filter caps (bulging tops) which is the common failure in LCD TV and Monitors.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 12, 2011 | Gateway FPD1950
Windows XP on my Gateway PC will not accept Viewsonic Widescreen VA1912wSeries . My HP PC broke & I moved the montor to the Gateway. The HP had the same Windows XP system.
Reboot the computer into safemode. to do this tap F8 after the logo screen for gateway goes away. select Safe Mode.
Right click the desktop and click properties. in this window click settings. change the resolution to 1024x768.
click the advanced button. click monitor tab then set the screen refresh rate to 60 hertz.
if the monitor is compatible it will be able to be displayed. else try 1440x900 and 60Hertz for the settings
Feb 12, 2010 | ViewSonic VX2035WM LCD Monitor
Monitor resolution (slider) stuck on 4 bit color setting . . .
I would go to input your model and os then dload and install drivers for the motherboard.This should fix the problem.
Thanks for posting and please rate
Mar 16, 2009 | Computers & Internet
Old gateway essential 400c PC
yes, a 400 mhz processor can run windows xp, but you will want to have a LOT of ram. i would not recommend it unless you have at 256-512 or more ram.
windows 2000 can get along with 128-256 ram.
Sep 20, 2008 | Gateway Essential 400C SE PC Desktop
Monitor screen displays sideways
if the screen is rotated then press
ctrl + alt + up arrow
your screen will be placed correctly
this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
the hot key will be enabled defaultly so your screen got rotated
Jul 05, 2008 | Gateway FPD1950
Gateway monitor model Fpd 1950
It's probably cheaper to get a new monitor than it is to get a logic board. If Gateway can even get you such a thing.
Good luck on that.
Jun 15, 2008 | Gateway FPD1950
Gateway fpd1950 lcd monitor two years old.
check the card in the computer, it may need to be pushed back in place.
Nov 16, 2007 | Computers & Internet
Gateway monitors not powering on
Do you get an Amber light on either monitor?
Jun 21, 2007 | Gateway FPD1950
Computers & Internet Logo
461 people viewed this question
David Payne
David Payne
